Finding the strobilization of the magnetization at sphrerical coordinates.
In summary, you find that the surface current bound gives:\frac{\mu_oMr}3sin\theta \hat{e_\varphi} for r<R\frac{\mu_oMR^3}3\frac{1}{r^2}sin\theta \hat{e_\varphi } for r>R
vchris5
If the magnetization of a sphere is:
[tex]\vec{M} = \hat{\phi }\frac {r}{R}sin\theta M_{o}[/tex]
How much are the captive streams:
[tex]J_{b}=\vec{\bigtriangledown }\times \vec{M}[/tex]
[tex]K_{b}=\vec{M}\times \hat{n}[/tex]
I find that the first is:
[tex]J_{b} = \frac {2M_{o}}{R}(cos\theta \hat{r} - sin\theta \hat{\theta })[/tex]
but i don't know if that is correct and the point that i really want help is how to work the K.
Thank you a lot.
Thank you a lot.
I've never heard the term "captive streams" before, in English [itex]\vec{J}_b[/itex] and [itex]\vec{K}_b[/itex] are usually called "bound currents"
Your solution for the bound volume current [itex]\vec{J}_b[/itex] is correct :smile:...As for the bound surface current [itex]\vec{K}_b[/itex], what is the outward normal direction [itex]\hat{n}[/itex] for a spherical surface?
Hello gabbagabbahey,
You are right about the term "bound currents".
For the surface current [itex] \vec{K}_b [/itex] , the normal direction [itex] \hat{n} [/itex] is always vertical to the spherical surface.But how are the coordinates of [itex] \hat{n} [/itex] to put them to the type of strobilization..??
Thanks a lot for your interest.
I'm not sure what "strobilization" means... are you translating this from another language?
Also, the surface normal is always perpendicular to the surface, not "vertical":wink:...In spherical coordinates, [tex]\hat{n}=\hat{r}[/tex]...do you see why?
With the word strobilization I mean the [tex]\vec{M}\times \hat{n}[/tex].
Sorry but my English are not so good with the physics terms..
Oh yes, i see. So the surface current bound must be:
[tex]K_{b}=\frac{r}{R}sin\theta M_{o}\hat{\theta }[/tex] ?
looks good to me:approve:
I guess by "strobilization", you maybe mean "vector cross product"?
gabbagabbahey first of all, thanks a lot.
And the next problem is how is the A(x) with these current bounds??
vchris, first of all, your welcome!:smile:
And next, use the integral equations for the vector potential A:
[tex]\vec{A}(\vec{r})=\frac{\mu_0}{4\pi} \int_{\mathcal{V}} \frac{\vec{J}_b}{|\vec{r}-\vec{r}'|}dV'+\frac{\mu_0}{4\pi} \oint_{\mathcal{S}} \frac{\vec{K}_b}{|\vec{r}-\vec{r}'|}dA'[/tex]
I know this formula. I will try to find a solution and i will upload it to be able to compare...!
Thanks again!
I found that the surface current bound gives:
[tex]\frac{\mu_oMr}3sin\theta \hat{e_\varphi}[/tex] for r<R
[tex]\frac{\mu_oMR^3}3\frac{1}{r^2}sin\theta \hat{e_\varphi }[/tex] for r>R
But i can't find a solution for the other current bound
FAQ: Finding the strobilization of the magnetization at sphrerical coordinates.
What is meant by strobilization of magnetization at spherical coordinates?
Strobilization of magnetization at spherical coordinates refers to the phenomenon where the magnetization of a material aligns itself with the spherical coordinate system, which consists of radial, azimuthal, and polar coordinates.
Why is it important to find the strobilization of magnetization at spherical coordinates?
Understanding the strobilization of magnetization at spherical coordinates is crucial in studying the behavior of magnetic materials and their interactions with external magnetic fields. It also has practical applications in various fields such as magnetic data storage and imaging.
What factors affect the strobilization of magnetization at spherical coordinates?
The strobilization of magnetization at spherical coordinates is influenced by factors such as the material's magnetic anisotropy, the strength and direction of the external magnetic field, and the shape and size of the material.
How is the strobilization of magnetization at spherical coordinates measured?
The strobilization of magnetization at spherical coordinates can be measured using techniques such as magnetometry, which measures the magnetic moment of a material, or Kerr microscopy, which visualizes the orientation of magnetization in a material.
What are the applications of strobilization of magnetization at spherical coordinates?
The strobilization of magnetization at spherical coordinates has various applications in fields such as material science, nanotechnology, and geophysics. It is also essential in the development of new technologies such as spintronics and magnetic sensors.
