Finding the tension in terms of mg
In summary, the tensions in the cables attached to pulley 3 and 6 are both T. The tensions in the cables attached to pulley 2 and 7 are T/2. The tension in the cable attached to pulley 4 is also T/2, but in the opposite direction. The tension in the cable attached to pulley 5 is T/4, since it is shared by both sides of the turnbuckle.
yugeci
61
Attached the question.
(total) tension = mg
I'm not sure how the tension gets divided here. I know the tension on the right hand side of the turnbuckle is the same tension on the left hand side since they are symmetrical. But when does the tension get divided in the pullies, and by how much, I don't know. Help would be appreciated.
Start labeling the tensions and analyzing each pulley. You know there must be equilibrium, so use that.
I'm not sure how you analyze each pulley separately. I know each of the two cables directl attached to the turnbuckle will have a tension of T/2. I don't know how to divide it from there. How do the cables attached to the ceiling or ground affect T?
What must be the net force on each?
Good. Keep going. Now that you know that those cables have a tension of T/2, what else can you deduce? Follow the cable.
I'm a bit confused. Since T = mg, and mg acts downwards, that would mean the cables with the T/2 force would have to act upwards, right?
Also, does the tension of a pulley always act away from the pulley? If I did this, the first cable attached to the ceiling from either side would have a tension of T (Tx = T/2 + T/2). The first cable attached to the ground would have a tension of -T (T/2 + T/2, but acting downwards). The 2nd cable attached to the ceiling would have a tension of (T/2 - T/2) = 0.
And the 2nd cable attached to the ground would have a tension of (T/2 + T/2) = T..
But this gives 2(T - T + T) = 2T = mg, T = mg/2 which is clearly wrong.. what is my mistake?
Hopefully I am making sense.
No, not right. Why do you think T = mg? (The problem asks to solve for T.)
Let's do things systematically. Label the 8 pulleys 1 through 8 going from left to right (that way we can refer to them unambiguously). So, what can you say about the tensions in the cables attaching to pulley #3?
Oh right. Makes sense.
OK. Here's my deduction:
A tension T/2 exists in the cable attached to the left hand side of the turnbuckle. So a tension of T/2 would be exerted by pulley 4 on both cables. Both acting away from the pulley. Since the cable on the left hand side of pulley 4 is connected to a cable of pulley 3, the tension exerted by the cable on pulley 3 would also be T/2, and therefore the tensions exerted by pulley 3 on the cables would also be T/2, just in the opposite directions.
So pulley 3 would exert a tension of T/2 on both cables. Both tensions would act upwards. Since the net upwards force would have to equal the net downwards force of each pulley, the cable attached to the ground of pulley #3 would be -(T/2 + T/2) = -T..
The problem I have is that I'm not sure about my directions.. and how the tension of the cables attached to the ceiling or ground would affect things.
Good. You correctly deduced that the ground cable attached to pulley #3 pulls down on pulley #3 with a force of T. Thus the tension in that cable is T. (And, by symmetry, you know the tension in the bottom cable attached to pulley #6.)
Keep going! Next: Analyze the forces on pulley #2.
You're getting there. So far you have expressions for the tensions in 3 of the 5 cables attached to the mass.
OK after some calculations I got the ceiling cable tension of pulley #2 (and therefore #7) as 0 (T/2 + ceiling tension = T/2). And the ceiling cable of pulley #1 (and therefore #8) as T (upwards). However I assume we are only needed in the ground cables, and the grounded cable of pulley #1 and pulley #8 should have a tension of T/2 each..
I take it I'm wrong here, and that the tension of T1 and T8 are actually T/4 since that's what's mentioned in the solution manual. I'm not sure what I did wrong though.
I don't understand your reasoning here. You have a tension of T/2 acting downward on pulley #2, so what must be the tension in the cables pulling up on that pulley?
Oh right, T/4..
With this logic the grounded cables on T1 and T8 would be T/4? And that would give the total tension on the mass as 3T + T/4 + T/4 = 3.5T?
So 3.5T = mg?
Is this correct?
yugeci said:
Oh right, T/4..
So 3.5T = mg?
Is this correct?
Right!
So what's T in terms of mg? (Express it as a fraction.)
T = (2/7) mg.
Thank you so much for the help. It feels great to solve this with your help.
Appreciated. :)
Good work! :thumbs:
Likes 1 person
FAQ: Finding the tension in terms of mg
What is tension in terms of mg?
Tension in terms of mg refers to the force exerted on an object due to its weight. It is calculated by multiplying the mass of the object by the acceleration due to gravity (g).
How do I find the tension in terms of mg?
To find the tension in terms of mg, you will need to know the mass of the object and the acceleration due to gravity. Then, simply multiply the mass by g, which is typically 9.8 m/s^2.
What is the formula for calculating tension in terms of mg?
The formula for calculating tension in terms of mg is T = mg, where T is the tension, m is the mass of the object, and g is the acceleration due to gravity.
Can tension be negative in terms of mg?
No, tension cannot be negative in terms of mg. This is because tension is a force, and forces are always positive values. If the calculated tension is negative, it means there was an error in the calculation.
How does tension in terms of mg differ from other forms of tension?
Tension in terms of mg is specific to the force exerted on an object due to its weight. Other forms of tension may refer to the force between two objects or the force applied to an object by a person. The calculation and units may also differ between different forms of tension.
