Finding the time in which a potential drop is equal to 3V
In summary, the problem involves a capacitor, C1, initially charged to 12V and discharged through resistor R1 when switch S1 is closed. At t=5, the potential across the capacitor is 6V and the goal is to find the time at which it reaches 3V. Using the equation V=Voe^(-t/RC), we can solve for RC by plugging in the given values of 6V and 12V. This gives us RC=7.21 seconds. Then, plugging in RC and the desired potential of 3V, we can solve for the time t, which is equal to 10 seconds.
grace85233
Capacitor, C1, is initially charged so that it has a potential difference of 12V. At time t=0, switch S1 is closed allowing the capacitor to discharge through resistor R1. At t=5, the potential across the capacitor has fallen to 6V. At what time will the potential across the capacitor reach 3V?
V=Voe^(-t/RC)
6=12e^(-5/RC)
The RC is confusing to me. I'm not sure how what I'm supposed to do with it.
V=Voe^(-t/RC)
6=12e^(-5/RC)
If 6=12e^(-5/RC), what does RC have to be to make that equation true?
It would equal 5ln(2), but I don't know how to use that for the answer. If I plug it in, there are lots of natural logs.
Not quite - you made a division error. Double-check the time again. Also, you should keep track of the units.
Once you've found RC, it may involve a natural log, but sometimes things just involve natural logs. At any rate, it's just a number, so you can now solve for the time at which V = 3 volts, and then you can plug in the number for RC to get a numerical answer for the time at which V = 3 V. Does that make sense?
I went from
6=12e^-5(RC)
ln(1/2)=-5/RC
RC=7.21
Is that correct?
grace85233 said:
I went from
6=12e^-5(RC)
ln(1/2)=-5/RC
RC=7.21
Is that correct?
Yes, that is correct. Note that that is 5/ln(2), whereas before you wrote 5*ln(2).
So RC = 7.21... what? What are the units? (Did your problem tell you the units? You didn't list any in your problem statement).
Anywho, now that you have RC = 7.21, can you solve for the time at which V = 3 volts?
RC is in s.
So then it would just be
3=12e^(-t/7.21)
t=10s
grace85233 said:
RC is in s.
3=12e^(-t/7.21)
t=10s
Yep, looks good.
Thank you!
FAQ: Finding the time in which a potential drop is equal to 3V
How can I calculate the time in which a potential drop is equal to 3V?
To calculate the time in which a potential drop is equal to 3V, you will need to know the resistance and capacitance values of the circuit. You can then use the formula t = RC, where t is the time, R is the resistance, and C is the capacitance.
Can I use Ohm's Law to find the time in which a potential drop is equal to 3V?
No, Ohm's Law (V = IR) is used to calculate the voltage, current, or resistance in a circuit. It cannot be directly used to find the time in which a potential drop is equal to 3V.
Is there a specific unit for measuring the time in which a potential drop is equal to 3V?
Yes, the unit for time in which a potential drop is equal to 3V is seconds (s).
What is the significance of finding the time in which a potential drop is equal to 3V?
Finding the time in which a potential drop is equal to 3V is important in understanding the behavior of a circuit and how quickly it can reach a certain voltage level. It is also useful in designing and troubleshooting electrical systems.
Are there any other factors that can affect the time in which a potential drop is equal to 3V?
Yes, the time in which a potential drop is equal to 3V can also be affected by the type of circuit, the presence of other components, and external factors such as temperature and humidity. These factors should also be taken into consideration when calculating the time in which a potential drop is equal to 3V.
