Finding the time period using the potential
In summary: Taylor series with respect to ε? I am sorry I am not really familiar with the first one (in case it's not the Taylor series). Also, I have edited my previous comment, I don't know if you could see it but anyway, when I try to open the brackets, I do not know how to proceed. I get crazy expressions with high powers and when I try to solve the integral with arcsin, I get a long thing with more than one arcsin and I am not sure how to simplify them. Thanks in advance!To expand to first order in ε, use only the first two terms of the Taylor series expansion of##\sqrt{1+ \epsilon(a^4-x^4)}
green-beans
36
A particle of unit mass moves in one dimension with potential V(x) = ½μ2x2 + εx4 (ε>0). Discuss the motion of the particle.
If the particle released from rest at x=a (a>0) express the time period T for the particle to return to a in the form of an integral and show that when ε is small, T is reduced by approximately 3επa23.
v = dx/dt = ±√{(2/m) * (E - V(x))}
Time period taken for a particle to move from point x1 to x2:
T = ∫1/{v} dx
Discuss the motion:[/B]
If we sketch V(x) it will look alike to parabola with V(0) = 0. Depending on the value of E that the particle has, it will have a simple harmonic motion and will oscillate in the region enclosed between E and the x-axis.
Time period to return to a:
I obtained this and it matched with the answers (sorry for the long expression I wanted to upload a picture but it did not work)
T=(4/μ) ∫(dx)/(√{(a2-x2) +(2/μ2)ε(a4-x4)})
Show that T is reduced by approximately 3επa23
In this part I am not sure how the fact that ε is small will affect the integral. I am not sure how small the numerator will become and whether the denominator will be greater than numerator. In this case should I just integrate?
Thank you for your help!
##\varepsilon## is assumed to be small enough such that ##\frac{2}{\mu^2} \varepsilon (a^4 - x^4)## is small compared to ##a^2 - x^2##. Expand ##\left[a^2 - x^2 + \frac{2}{\mu^2} \varepsilon (a^4 - x^4) \right]^{-1/2}## to first order in ##\varepsilon##.
green-beans said:
Discuss the motion:
V(x) will look approximately like a parabola, but it is not a true parabola. So, although the particle will oscillate, is the motion simple harmonic motion?
Hi, thank you for your comments! Regarding the part with ε, could you please specify what do you mean by "expand to first order in ε"? Do you mean to expand (2/μ2) * ε(a4−x4) using Taylor series and then take the first two terms?
As for the description of the motion, I thought that the particle will oscillate between two points depending where it starts on the graph and so will oscillate in a similar way to a pendulum. However, I am not sure if it's SHM or not since when oscillating the particle will be likely to lose some of its energy and so the amplitude of its oscillations will reduce. At the same time the particle will lose some of its energy due to external forces and the question does not mention any and so I am not sure if I can assume that or not.
Thank you once again!
No, expand
green-beans said:
1/√{(a2-x2) +(2/μ2)ε(a4-x4)})
haruspex said:
No, expand
I am sorry but I do not quite understand whether you mean to expand using Taylor series or not and if yes, about what x_0? I tried expanding it around x_0=0 and my first derivative gave me 0 leaving me with only f(0) as an approximation, and obviously this cannot be the case since we will not be able to get pi in the final expression. I also tried opening the brackets and completing the square. Then I used arcsin to solve the integral and I got a very long scary expression which I can't really simplify :(
I am sorry for being slow but I can't really see what else I can do.
I took a look at this, but I must confess I don't understand the question. If ##\epsilon## is small, then ##T## is reduced by something compared with what?
Edit: is it compared with ##\epsilon = 0##?
Yes, it is compared with the time period when ##\epsilon = 0##.
Thanks @ehild
@green-beans I would take out a factor of ##(a^2 - x^2)##, if you haven't already. Also, it's easier to use the Binomial expansion than try to differentiate your function for the Taylor series.
green-beans said:
Hi, thank you for your comments! Regarding the part with ε, could you please specify what do you mean by "expand to first order in ε"? !
You have to expand with respect to ε and stop at the first-order term.
As @PeroK suggested, first take out the factor a2-x2 from ##
, and expand the other factor with respect to ε. Note that a4-x4=(a2-x2)(a2+x2).
So, by saying to expand with respect to ε, do you mean to take x_0 = ε?
No. Take ε_0=0.
ehild said:
No. Take ε_0=0.
Oh, so you differentiate as well in respect to epsilon and regard it as a function of ε and expand it using Taylor series around epsilon =0?
Sorry for asking so many questions. It's just I tried expanding it, and I did not get the right answer
That's another way to do it. But, the most obvious way is just to think of ##\epsilon## as some small number and find the difference between the two integrals: one with ##\epsilon = 0## and the other with some small number. You should recognise the set-up for using the Binomial expansion.
Thank you for your help! I still keep on getting something close to the answer but I can't figure out what I am doing wrong. Here I attached the link to my solution: https://drive.google.com/open?id=0BzewpRKo76bDWWNld1U3SHNBVEk
It looks like you just have a couple of algebraic lapses in there somewhere. Easily done and hard to spot!
I can't immediately pin down where you've gone wrong.
I got:
##T = \frac{2}{\mu} \int_{-a}^{a} (a^2 - x^2)^{-\frac12} [1 + \frac{2\epsilon}{\mu^2}(a^2 + x^2)]^{-\frac12} dx##
Do you get that?
I got:
Do you get that?
Oh, I think I copied the initial integral incorrectly. I'll redo it again and I'll get back here :) thank you once again
Just get that integral above and hit it with the Binomial! It's much simpler.
So, I got a similar integral but in front of it I got 4/μ and the limit between 0 and a. So, that should be the same thing. When using Taylor series for ε I then obtain two integrals. The first one is 1/sqrt(a^2-x^2)^(-1/2). The second one (-ε/μ^2)*(a^2+x^2)/sqrt(a^2-x^2). When solving the integral, I still get the wrong answer which is (4/μ) (pi/2 - (ε/μ^2)*(3pia^2/4) which would have been the answer if I did not get pi/2 for the first term. So, I am not sure what I am doing wrong since I redid the integral several times :(
The first integral is the period when ##\epsilon = 0##, so only the second integral is the difference when ##\epsilon \ne 0##.
But I got the first integral by multiplying (sqrt(a^2-x^2)^(-1/2)) by the first term of Taylor expansion which was 1 and the second integral - by multiplying by the second term of expansion (i.e. the one with first derivative) and in both cases I had ε_0 = 0 and so I do not quite see how only the second integral is the solution for small ε. Since I thought the whole expansion (first and second term) will demonstrate the behaviour of the function as ε gets closer to 0.
(4/μ) (pi/2 - (ε/μ^2)*(3pia^2/4)) You dropped a parenthesis. The expression is the total time T, not the difference ΔT caused by the εx^4 term in the potential.
The problem asks:
Likes PeroK
The problem asks: .
Ohhh, so, it asks for how much the time period is reduced by compared with the time period when epsilon is zero? So, I need to find delta T which is the difference between when epsilon is zero and when it's small.
Thank you so much and so sorry for asking that many questions. I think I now understand!
See posts #7 and #8.
FAQ: Finding the time period using the potential
1. How do you find the time period using the potential?
To find the time period using the potential, you must first determine the equation for the potential energy of the system. Then, use this equation to solve for the position and velocity of the object at different points in its motion. Finally, use these values to calculate the time period using the formula T = 2π√(m/k) where m is the mass of the object and k is the spring constant.
2. What is the equation for potential energy of a system?
The equation for potential energy of a system is U = 1/2 * k * x^2, where U is the potential energy, k is the spring constant, and x is the displacement from equilibrium.
3. Can the potential energy be negative?
Yes, the potential energy can be negative. This usually occurs when the object is below its equilibrium position, and the potential energy is then considered to be the difference between the total energy and the kinetic energy of the object.
4. How does the mass of the object affect the time period?
The mass of the object affects the time period by directly influencing the period of oscillation. As the mass increases, the period also increases, since it takes more time for a heavier object to complete one full oscillation.
5. What happens to the time period if the spring constant is doubled?
If the spring constant is doubled, the time period is halved. This is because the spring constant is directly proportional to the time period, so increasing it will result in a shorter period of oscillation.
