garcia1
- 27
A ball is thrown from the top of a building upward at an angle of 35◦ to the horizontal and with an initial speed of 10 m/s. The ball is thrown at a height of 43 m above the ground.
How long is the ball “in flight”? The acceleration due to gravity is 9.8 m/s2 .
Answer in units of s.
Kinematics equations and their vector components
I wanted to try breaking this problem up into two different segments and solve for the time of each of them.
segment one, I wanted to find the time of the ball as it arcs at the angle of 35 degrees until it begins to descend past the height from which it was thrown.
I decided to find the y component of the velocity by using trigonometry. I used the equation sin(35) = Vy/10m/s and solved for Vy, getting 5.736.
Since this velocity points downward as it ascends, I labeled this velocity as the Vf of this segment, -5.736m/s.
Using kinematics equation Vf = Vo +at, I solved for t, using Vo as the point where Vy is at the top, with no movement, 0m/s.
My answer was -.5847s, so I'm not sure if I messed up on my conceptual layout or if I can just interpret this segment as a positive, since time can only be positive.
Past this, I'm pretty lost. Any thoughts?
