Finding the total hydrostatic force that can be withstood
In summary: What is the area of the object? That's not very clear. Also, it would be helpful if you could give an equation for the pressure.For part "b," I'm a little confused as to how to solve it. I set 160 equal to the line above, and then just divide both sides by 100...Then, since the powers are negligible with limits of integration of 0 and 1, I get 1.6 = 4y/3 - 2y/5 --> 1.6 = 14y/15 ---> y = 1.7143, and that's definitely not the answer I'm looking for.If you divide both sides of the equation by 100, you get 1.6 = 14/100. This is definitely
leo255
57
[/B]
We are given a cubic tank, with a parabolic object y = x^2 (one end is -1, 1 and the other is 1, 1 --> it only goes up to 1). The total pressure it can withstand is 160 lbs. Also, the fluid density is 50 lbs.
Find:
a) Total pressure if water is 2-feet deep.
b) Max height the tank can be filled.
Fluid density is 50 lbs.
Total pressure that can be withstood by the object: 160 lbs
3. The Attempt at a Solution
I think I got most of this:
For part "a," I'm getting a pressure of 50 (2-y), and for the area of the object, I'm getting 2 root(y) dy.
Thus, I got the integral, from 0 to 1, of 100 (2-y)(root(y)), and then got:
100 [4y^(3/2) / 3 - 2y^(5/2) / 5], from 0 to 1, and the answer I got was about 93.33 lbs of total pressure.
leo255 said:
[/B]
Find:
How does the "parabolic object" tie into the problem? The situation isn't at all clear from your problem description. A picture would be helpful, but you at least need to give a better description of what the problem is about.
Fair enough - Here is a very basic picture:
http://postimg.org/image/kcxr9rgwp/
EDIT: I think I had a brain-fart - The picture on the RIGHT is correct. On the left, it should look like the graph picture (y = x^2).
leo255 said:
[/B]
Find:
Fluid density cannot be 50 lb; it can be 50 lb "per cubic something or other", but you need to specify what that would be. Also: pressure cannot be 160 lb, but it can be 160 lb "per square something or other". So, you need to decide if when you say "pressure" you actually pressure, or do you really mean "total force"? It makes a real difference.
Let's be more precise. The above is the pressure on a thin horizontal strip. When you integrate, you're getting essentially the sum of the pressures on a bunch of thin horizontal strips.
Your integral looks like this:
$$\int_0^1 50(2 - y) 2\sqrt{y}dy$$
The LaTeX for the above is this (but the spaces between the pairs of $ symbols has to be removed).
Code:
 $ $\int_0^1 50(2 - y)2\sqrt{y}dy $ $
Seems OK to me.
No, it's a bit more involved than that. When you were calculating the pressure on a thin horizontal strip, the "head" was (2 - y), the distance from the top of the fluid to the horizontal strip. You need to treat the top level of the water as a variable (don't use y). Write that integral and set it equal to 160, and solve for your variable.
Related to Finding the total hydrostatic force that can be withstood
What is hydrostatic force?
Hydrostatic force is the force exerted by a fluid on an object due to the pressure of the fluid at a particular depth.
How is hydrostatic force calculated?
Hydrostatic force is calculated by multiplying the density of the fluid, the acceleration due to gravity, and the height of the fluid column above the object.
What factors affect the total hydrostatic force that can be withstood?
The total hydrostatic force that can be withstood is affected by the density of the fluid, the depth of the fluid, and the area of the object that is in contact with the fluid.
How does the shape of an object impact the hydrostatic force it can withstand?
The shape of an object plays a significant role in the hydrostatic force it can withstand. Objects with a larger surface area facing the fluid will experience a greater hydrostatic force than objects with a smaller surface area.
What is the practical application of finding the total hydrostatic force that can be withstood?
Knowing the total hydrostatic force that an object can withstand is crucial in engineering and construction to ensure the stability and integrity of structures that will be exposed to fluid forces, such as dams, bridges, and ships.
