MHB Finding the Value of a Summation Limit Problem
Saitama
Problem:
Find the value of
$$\lim_{n\rightarrow \infty} \sum_{r=0}^n \left(\frac{1}{4r+1}-\frac{1}{4r+3}\right)$$
Attempt:
I tried writing down a few terms to see if the terms cancel but no luck there. I couldn't find any closed form for the summation. :(
Next, I thought of converting it into a definite integral. The usual approach is to consider $r/n$ as $x$ and $1/n$ as dx but I am unable to find a way to do this.
I am completely clueless now. (Doh)
Any help is appreciated. Thanks!
Pranav said:
Problem:
Find the value of
Attempt:4\ r + 3
The first step is to transform Your series in...$\displaystyle S = \sum_{r=0}^{\infty} (\frac{1}{4\ r + 1} - \frac{1}{4\ r + 3}) = \frac{1}{8}\ \sum_{r=0}^{\infty} \frac{1}{(r + \frac{1}{4})\ (r+ \frac{3}{4})}\ (1) $
... and the second step is to apply the (5.32) of...http://mathhelpboards.com/discrete-mathematics-set-theory-logic-15/difference-equation-tutorial-draft-part-i-426.html#post2494$\displaystyle \sum_{r=1}^{\infty} \frac{1}{(r + a)\ (r + b)} = \frac{\phi(b) - \phi(a)}{b - a}\ (2)$
... where... $\displaystyle \phi (x) = \frac{d}{dx} \ln x!\ (3)$
... so that we obtain...
$\displaystyle S = \frac{2}{3} + \frac{1}{4}\ \{\phi(\frac{3}{4}) - \phi(\frac{1}{4})\}\ (4)$
The successive step is numerical evaluation of (4) and it will be performed in next post...
Kind regards
$\chi$ $\sigma$
Using 'Monster Wolfram' we find the [quite surprising...] result ...
$\displaystyle \phi(\frac{3}{4}) = \frac{4}{3} - \gamma + \frac{\pi}{2} - \ln 8$
$\displaystyle \phi(\frac{1}{4}) = 4 - \gamma - \frac{\pi}{2} - \ln 8$
... so that is...
$\displaystyle S = \frac{2}{3} + \frac{1}{4}\ (\pi - \frac{8}{3}) = \frac{\pi}{4}$
... and that suggests that a more confortable way exists to arrive at the result... Kind regards $\chi$ $\sigma$
Pranav said:
Problem:
Find the value of
Attempt:
We can use the digamma function
We can regularize a divergent infinite sum to give it a finite value
$$\sum_{n\geq 0}\frac{1}{n+a}=-\psi(a)$$
So
$$S=\frac{1}{4}\sum_{r=0}^\infty \left(\frac{1}{r+\frac{1}{4}}-\frac{1}{r+\frac{3}{4}}\right)=-\frac{1}{4} \left(\psi\left(\frac{1}{4}\right) -\psi\left(\frac{3}{4}\right)\right)$$
Now use the reflection formula
$$\psi(1-x)-\psi(x)=\pi\cot(\pi x)$$
so
$$\psi\left(\frac{1}{4}\right) -\psi \left(\frac{3}{4}\right) =-\pi\cot \left(\frac{\pi}{4} \right)=-\pi$$
Hence
$$S=\frac{\pi}{4}$$
- - - Updated - - -
Interestingly using the regulaized representation we can find that
$$\sum_{n\geq 0}\frac{1}{n+1}=\sum_{n\geq 1}\frac{1}{n}=-\psi(1)=\gamma$$
So
$$\lim_{n \to \infty }H_n = \gamma$$
$$ \sum_{r=0}^{\infty} \Big( \frac{1}{4r+1} - \frac{1}{4r+3} \Big) = \sum_{r=0}^{\infty} \int_{0}^{1} \Big( x^{4r} -x^{4r+2} \Big) \ dx$$
$$= \int_{0}^{1} \sum_{r=0}^{\infty} \Big(x^{4r}-x^{4r+2} \Big) = \int_{0}^{1} \frac{1-x^{2}}{1-x^{4}} \ dx = \int_{0}^{1} \frac{1}{1+x^{2}} \ dx = \frac{\pi}{4}$$
Hi chisigma! :)
Kind regards
$\chi$ $\sigma$
That looks way too complicated for me to comprehend. I have never dealt with anything like what's shown in your tutorial and it isn't even my coursework too. :confused:
Is there no other way to solve this problem? I doubt I need to go through such complicated stuff for this problem because it is an exam problem.
So
so
Hence
$$S=\frac{\pi}{4}$$
- - - Updated - - -
So
Thank you for your participation ZaidAlyafey but unfortunately that's no better, it still requires a level of Math I haven't reached. :(
That's out of my coursework, I haven't yet seen the gamma function and you ask me to look for digamma function. :p
Hi Random Variable!
Sorry if this is obvious but how do you convert the fractions into powers of x? :confused:
Thank you!
$$ \int_{0}^{1} x^{4r} = \frac{x^{4r+1}}{4r+1} \Big|^{1}_{0} = \frac{1}{4r+1}$$
$$ \int_{0}^{1} x^{4r+2} = \frac{x^{4r+3}}{4r+3} \Big|^{1}_{0} = \frac{1}{4r+3}$$
Actually it might be enough to reckognize that
$$\sum_{n\geq 0}\frac{1}{4r+1}-\frac{1}{4r+3}=1-\frac{1}{3}+\frac{1}{5}-\frac{1}{7}+\cdots =\sum_{n\geq 0}\frac{(-1)^n}{2n+1}=\frac{\pi}{4}$$
Where we use the series representation of $$\arctan(x)=\sum_{n\geq 0}\frac{(-1)^n}{2n+1}x^{2n+1}$$
by putting $$x=1$$.
That's very cool! :cool:
This trick looks very useful, thanks a lot Random Variable! :D
Do you know where can I find similar problems (book or a link)? I feel that the method you have shown might help me again somewhere so I want to try a few more problems, thank you! :)
by putting $$x=1$$.
Yes, I see it. I am sure the series representation would have never have occurred to me because I am much more used to dealing with series of sines and cosines. Thank you ZaidAlyafey! :)
Unfortunately I don't have a link to similar problems.
But here's another simple example.
Somehow this didn't come up in a challenge thread about ways to evaluate the alternating harmonic series.
$$\sum_{n=1}^{\infty} \frac{(-1)^{n+1}}{n} = \sum_{n=1}^{\infty} (-1)^{n+1} \int_{0}^{1} x^{n-1} \ dx = \int_{0}^{1} \sum_{n=1}^{\infty} (-1)^{n+1} x^{n-1} \ dx$$
$$ = \int_{0}^{1} \sum_{n=0}^{\infty} (-1)^{n+2} x^{n} = \int_{0}^{1} \sum_{n=0}^{\infty} (-1)^{n} x^{n} \ dx = \int_{0}^{1}\frac{1}{1+x} \ dx = \ln 2$$
Thanks a lot Random Variable! :)
For alternating sums , it's always helpful to look at even and odd terms $$\sum_{n\geq 0}\frac{(-1)^n}{2n+1}=\sum_{n\geq 0}\frac{1}{4n+1}-\frac{1}{4n+3} $$
where we have for even terms
$$\sum_{n\geq 0}\frac{(-1)^{2n}}{4n+1}=\sum_{n\geq 0}\frac{1}{4n+1}$$
and odd terms
$$\sum_{n\geq 0}\frac{(-1)^{2n+1}}{2(2n+1)+1}=-\sum_{n\geq 0}\frac{1}{4n+3}$$
