Finding the Value of Gravity Given Height and Velocity
In summary, the ball's velocity increases until it hits the ground, and its potential energy is converted into kinetic energy. The ball's gravity is 10.7 meters per second squared.
Oannes
If a ball is dropped from a height (H) its velocity will increase until it hits the ground (assuming that aerodynamic drag due to the air is negligible). During its fall, its initial potential energy is converted into kinetic energy. If the ball is dropped from a height of 880cm, and the impact velocity is 43 feet per second, determine the value of gravity in units of meters per second squared.
Potential Energy = (mass)(acc of gravity)(height)
Kinetic Energy = 1.2(mass)(final velocity2 - initial velocity2)
=1.2(mass)(velocity)2 ///[FOR NONROTATING BODY]
Work = Force * Distance
I am really at a loss for this one. If I plug in impact velocity to find Kinetic Energy (which I don't think I can do since it gave me the impact velocity) I get the following:
KE = 1/2(m)(43f/sec)
If I plug in what I know for Potential Energy I get the following:
PE = m(g)880cm
Also once I convert the 2 I get:
H = 8.8m
iV = 13.72m/s
I do not see how I can solve anything here since I do not have KE or mass. I feel like I need another value before I can do anything, and I have looked extensively in my textbook for examples like this but I have found none that were answered. I also can't get the average velocity since I only know the impact velocity (I would assume it would be (43f/sec)/2), but even if I had that what would be the point? I have no idea where to start, in my class we have went over only the formulas posted and I can't think of a way to solve this. Thanks in advance.
This question is probably from a course unit on conservation of energy or the work-energy theorem.
What do you know about the relationship between the change in KE and the change in PE for a projectile?
Nothing really. This questions is for an introductory Engineering Class surprisingly (Engineering Problem Solving ENGR1300). I know that potential energy is weight (mass * gravity) * height and that Kinetic Energy is 1/2(mass)(velocity)^2. I also know that energy is Force * distance(or height). This is the extent, however. Most of the class is spent converting units and plugging them into given equations, however with the equations we were given here I do not see how that is possible. Below is a full list of the equations mentioned in the chapter we are on (although we have only used 3 so far: PE, KE, Q):
Work
W = F*deltaX
Potential Energy
PE = mg(deltaH)
Kinetic Energy, transitional
KET=1/2m(v2f - v2i)
Kinetic Energy, rotational
KER = 1/2(w2-w2)
Kinetic Energy, total
KE = KET + KER
Thermal Energy
Q = mCp(deltaT)
You also know that, in this case, the potential energy before the drop is equal to the kinetic energy at the end of the drop. That gives you an equation.
So I can set:
m(g)8m = 1/2m(13.72m/s)
But how does that help me solve for g?
You might want to choose a different variable name for mass to distinguish it from 'm' for meters if you're going to mix variables and numericals. maybe use M instead.
What cancels out in your equation? can you g?
Oannes said:
So I can set:
Ah I see, so these are the steps to find the equation for g:
mgH = 1/2m(v)2
g = (1/2m(v)2)/mH
g = 1/2(v)2/H ///because mass cancels out
Then I plug the info in
g = (1/2(13.72m/s)2) / 8.8m
g = (1/2(188.24m2/s2) / 8.8m
g = (94.12m2/s2) / 8.8m
g = 10.7m/s2
Awesome, this makes sense when I think logically about potential energy being the same as the kinetic once it stops. I think what confused me the most was not understanding if the velocity given at the stop was the one I was supposed to use. Thanks a bunch guys this one was a real brain-kicker. I take physics next semester so hopefully the information I get in this class will give me a nice little kickstart.
Your method is correct. You might want to check your conversion from ft/sec to m/sec for the velocity.
Thanks and yeah I caught that when entering my answer luckily.
There are many ways to solve this, which is one of the beauties of physics. Let's use basic kinematic equations for the definition of what acceleration and velocity are, then use the Law of Conversation of Energy and the formulas for energy.
d=8.80m
final v = 13.12 metres/s1)
we know that velocity is the change in velocity/s, thus a = Δv / t
The average velocity = Δd / Δt = (v + u) / 2
solving both for t
v - u / a = Δd / (v+u / 2)
simplifying it and solving for a
( v2 - u2 ) / 2 d = a
considering u = 0 then v^2 / 2 d = a = g
2)
because of conservation of energy, the work done to bring an object to a certain height = potential energy,
Work = F d
F = ma = mg
therefore Ep = mgd
the potential energy at d height = kinetic energy on impact,
mgd = 1/2mv2
thus v2=2gd
g= v2/ 2d
Related to Finding the Value of Gravity Given Height and Velocity
What is the formula for finding the value of gravity?
The formula for finding the value of gravity is g = 2h(v^2)/h^2, where g is the gravitational constant, h is the height, and v is the velocity.
How does height and velocity affect the value of gravity?
The higher the height and the greater the velocity, the stronger the force of gravity will be. This is because the distance between the object and the Earth's center decreases as the height and velocity increase, resulting in a stronger gravitational pull.
What is the significance of finding the value of gravity?
Finding the value of gravity is important in understanding the forces that act upon objects on Earth. It also helps in predicting the motion of objects and calculating things like projectile trajectories and orbits.
Can the value of gravity change?
The value of gravity can vary slightly depending on location and altitude, but it is considered a constant value. However, in extreme circumstances such as near a black hole, the value of gravity can be significantly different.
How is the value of gravity measured?
The value of gravity is typically measured using a device called a gravimeter, which measures the acceleration due to gravity (g) at a given location. This value is then compared to the standard value of 9.8 m/s^2 to determine the local value of gravity.
