Finding the vector equation of a plane
  • Thread starter Thread starter i_love_science
    Plane Vector
The discussion centers on finding the vector equation of a plane using specific points and direction vectors. The initial solution presents the equation as [6,0,0] + r[-2,3,1] + q[-2,2,3], where (6,0,0) is questioned as a point on the plane. A participant suggests an alternative point (4,2,3) and proposes a different equation format. The conversation highlights the need for clarification on the choice of point and the correctness of the alternative solution. The thread emphasizes understanding vector equations in relation to given points and direction vectors.
i_love_science
Find a vector equation of the plane that passes through the point (6, 0, 0) and contains the line 𝑥 = 4 - 2𝑡, 𝑦 = 2 + 3𝑡, 𝑧 = 3 + 𝑡.
vector equation
Solution:
u = [-2,3,1]
Po = (6,0,0) & P = (4,2,3)
PoP = v = [-2,2,3]
Therefore, the answer is [6,0,0] + r[-2,3,1] + q[-2,2,3]; r, q are real numbers
I don't understand why (6,0,0) is used as the point in the vector equation, since it only lies on the [-2,2,3] vector, not the u = [-2,3,1] vector.
My answer is r = [4,2,3] + r[2,-2,-3] + q[-2,3,1], r, q are real numbers
Could anyone explain the solution, and is my answer correct? Thanks.
Your answer is transformable to
[4,2,3]+q[-2,3,1]-r[-2,2,3]=[6,0,0]+q[-2,3,1]-(r-1)[-2,2,3]
changing q with r and -(r-1) with q, it equals to the text answer.
Likes i_love_science
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
