Finding the volume of a sphere with a double integral
In summary, the equation for the volume of a sphere with its center at the origin is 8∫01∫0√(1-y2)√(1-x2-y2)dxdy. However, when trying to solve for this volume, it is impossible to get an answer without first doing a trig substitution.
Sleepycoaster
I know how to find the volume of a sphere just by adding the areas of circles, so I decided to do a double integral to find the same volume, just for fun.
Here's what I've set up. I put 8 out front and designed the integrals to find an eighth of a sphere that has its center at the origin. This piece of the sphere is what you would get if you cut a sphere in half three times, one from each of the three dimensions.
8∫010√(1-y2)√(1-x2-y2)dxdy
√(1-x2-y2) is the equation I used to measure the z-dimension of a point on the sphere given values for x and y.
Here's the integral I got for the inner integration, the one with respect to x:
=[-2x/(2√(1-x2-y2))] with 0 on the bottom and √(1-y2) on the top.
As you can see, if I plug in √(1-y2) for x, the values cancel out so that there is only a zero in the denominator.
Is this simply a limitation in using multiple integration, or did I do something wrong? Any help is appreciated.
And yes, everything in this proof refers to a sphere with radius 1.
Here's what I've set up. I put 8 out front and designed the integrals to find an eighth of a sphere that has its center at the origin. This piece of the sphere is what you would get if you cut a sphere in half three times, from each of the three dimensions.
That antiderivative doesn't look correct. Try changing your dxdy integral to polar coordinates. It will be much easier. Otherwise you will need to do a trig substitution.
Likes 1 person
Oh hey, I see where I went wrong. I took the derivative when I should have taken the integral. Thank you!
Related to Finding the volume of a sphere with a double integral
Question 1: What is a double integral?
A double integral is a mathematical concept that involves integrating a function over a two-dimensional region. It is represented by two integral signs and is used to find the volume of a three-dimensional object, such as a sphere.
Question 2: How do you find the volume of a sphere using a double integral?
To find the volume of a sphere using a double integral, you first need to set up the integral using the formula V = ∫∫R(x,y)dxdy, where R is the region that encloses the sphere. Then, you can use the formula for the volume of a sphere, V = (4/3)πr^3, to solve the integral and find the volume.
Question 3: What is the region R for a sphere in a double integral?
The region R for a sphere in a double integral is a circle in the xy-plane with a radius equal to the radius of the sphere. This circle is centered at the origin and extends from -r to r in both the x and y directions.
Question 4: Can a double integral be used to find the volume of any three-dimensional object?
Yes, a double integral can be used to find the volume of any three-dimensional object as long as the region R can be defined and the integral can be evaluated.
Question 5: Are there any other methods for finding the volume of a sphere besides using a double integral?
Yes, there are other methods for finding the volume of a sphere, such as using the formula V = (4/3)πr^3 or using the shell method. However, using a double integral is a more general method that can be applied to finding the volume of other three-dimensional objects as well.
