Finding The Volume of An Air Bubble Just Before It Breaks Surface
In summary, the volume of an air bubble just before it breaks the surface can be calculated by using the formula V = 4/3πr³, where V is the volume and r is the radius of the bubble. It is important to know this volume as it can provide valuable information about the bubble's physical properties and has various scientific and industrial applications. Changes in temperature and pressure can affect the volume of the bubble. While accurately measuring the volume can be challenging, it is possible with specialized equipment and techniques. The volume of the bubble is closely related to its stability, with a larger volume indicating a more stable bubble and a smaller volume suggesting a less stable one.
jasminstg
At 24.0 m below the surface of the sea (density = 1025 kg/m3), where the temperature is 5.00°C, a diver exhales an air bubble having a volume of 0.90 cm3. If the surface temperature of the sea is 20.0°C, what is the volume of the bubble just before it breaks the surface?
_______ cm^3
Use P1V1/T1 = P2V2/T2.
Based on the given information, we can use the ideal gas law to calculate the volume of the air bubble just before it breaks the surface:
PV = nRT
Where:
P = pressure (in Pa)
V = volume (in m^3)
n = number of moles of gas
R = ideal gas constant (8.314 J/mol·K)
T = temperature (in K)
First, we need to convert the given values into the appropriate units:
- 24.0 m below the surface is equivalent to a pressure of 2.37 x 10^5 Pa (using the formula P = ρgh, where ρ is the density of seawater, g is the acceleration due to gravity, and h is the depth)
- 5.00°C is equivalent to 278.15 K
- 20.0°C is equivalent to 293.15 K
Next, we can calculate the number of moles of gas using the ideal gas law:
n = PV/RT = (2.37 x 10^5 Pa)(0.90 cm^3/100^3 m^3)/(8.314 J/mol·K)(278.15 K) = 3.61 x 10^-7 mol
Finally, we can plug in the new values into the ideal gas law to solve for the volume at the surface:
V = nRT/P = (3.61 x 10^-7 mol)(8.314 J/mol·K)(293.15 K)/(1.01 x 10^5 Pa) = 0.00000823 m^3 = 8.23 cm^3
Therefore, the volume of the air bubble just before it breaks the surface is approximately 8.23 cm^3. It is important to note that this calculation assumes that the temperature and pressure remain constant as the bubble rises to the surface. In reality, the bubble will likely expand due to the decreasing pressure, which may affect its volume just before it breaks the surface.
Related to Finding The Volume of An Air Bubble Just Before It Breaks Surface
1. How do you find the volume of an air bubble just before it breaks the surface?
The volume of an air bubble just before it breaks the surface can be calculated by measuring the diameter of the bubble, using the formula V = 4/3πr³, where V is the volume and r is the radius of the bubble. This is assuming that the bubble is perfectly spherical.
2. Why is it important to know the volume of an air bubble just before it breaks the surface?
Knowing the volume of an air bubble just before it breaks the surface can provide valuable information about the physical properties of the bubble, such as its surface tension and buoyancy. This information can be useful in various scientific and industrial applications, such as in the study of fluid dynamics and in the design of flotation devices.
3. How do factors such as temperature and pressure affect the volume of an air bubble just before it breaks the surface?
The volume of an air bubble just before it breaks the surface can be affected by changes in temperature and pressure. For example, an increase in temperature can cause the air inside the bubble to expand, resulting in a larger volume. Similarly, an increase in pressure can also cause the bubble to shrink in size.
4. Can the volume of an air bubble just before it breaks the surface be measured accurately?
While there are methods to accurately measure the volume of an air bubble just before it breaks the surface, it can be a challenging task due to the bubble's constantly changing shape and size. However, with the use of specialized equipment and techniques, it is possible to obtain precise measurements of the bubble's volume.
5. How is the volume of an air bubble just before it breaks the surface related to its stability?
The volume of an air bubble just before it breaks the surface is closely related to its stability. A larger volume generally indicates a more stable bubble, as it is able to withstand more external pressure before collapsing. On the other hand, a smaller volume may suggest a less stable bubble that is more likely to burst or merge with other bubbles.
