Fermat said:The shell Method:
When taking a volume of revolution about the y-axis, the formula is,
[tex]V = \int_{x_0} ^{x_1} xy \ dx[/tex]
where x is the radius of the shell, dx represents the shell thickness and y is the length, or height, of the shell.
Since, in this case, you are taking negative y-values, then you will get a negative answer for the volume. Simply change the sign.
You have two curves to contend with, so you should make up the integral like this,
[tex]V = \int_0 ^1 xy_1 \ dx + \int_1 ^2 xy_2 \ dx[/tex]
[tex]\mbox{where}\ y_1\ \mbox{is}\ \sqrt{x}\ \mbox{and}\ y_2\ \mbox{is}\ (x-2).[/tex]
yes,apmcavoy said:...don't you mean:
[tex]V=\mathbf{2\pi}\int_{a}^{b}xf(x)dx[/tex]
Sorry about the confusion there. I'm afraid I misread your work. Actually, I'd never heard of the shell method before.denian said:thank you, but I am a bit confused.
im doing some self-study here, and the formula they wrote in the book is what i wrote in the first line.
btw, the x-axis is the axis of rotation.
nvm. i try to figure it out again :)
The shell method is a technique used to find the volume of a solid of revolution, where the cross-sections are formed by shells (hollow cylindrical shapes) instead of discs or washers.
The shell method is typically used when rotating a function around a vertical axis, or when the function is difficult to integrate using other methods such as the disc or washer method.
The volume is calculated by integrating the circumference of the shell, multiplied by the height of the shell, over the desired interval. This can be represented by the formula V = 2π∫(radius)(height)dx.
The steps for using the shell method are:
Some common mistakes when using the shell method include:
