Finding the Wavefunction for Tunneling,with tunnel lenght L
In summary, the author finds that if the wave has energy greater than the potential barrier, it will tunnel through the barrier.
Arman777
Insights Author
193
Let us suppose we have a particle with energy ##E## and ##E<U## and the potential defined as
##U(x)=0## for ##x<0## (I)
##U(x)=U## for ##0<x<L## (II)
##U(x)=U_0## for ##x>L## (III)
In this case ##E>U_0## and ##U>U_0##
$$HΨ=EΨ$$
[/B]
I find the general form of solution, which it is
##Ψ(x)=Ae^{βx}+Be^{-βx}## for ##β^2=2m(U(x)-E)/\hbar^2##
For region (I) I find that
##Ψ_1(x)=c_1sin(\frac {\sqrt{2mE}} {\hbar}x)+c_2sin(\frac {\sqrt{2mE}} {\hbar}x)##
For region (II)
##Ψ(x)=De^{\beta x}+Ee^{-\beta x}## for ##\beta=\frac {\sqrt{2m(U-E)}}{\hbar}##
Is this true ? Because in the site of the hyperphysics it says it should be,
##Ψ(x)=Ee^{-\beta x}## for ##\beta=\frac {\sqrt{2m(U-E)}}{\hbar}##
I am not sure how we can derive this mathematically ? Why the
##De^{\beta x}## term vanishes ?
http://hyperphysics.phy-astr.gsu.edu/hbase/quantum/barr.html
For the region (III)
I find that
##Ψ(x)=Ge^{iαx}## for ##α=\sqrt{2m(E-U_0)}/ {\hbar}##
So ##D=0## or not ? If so why its 0 ?
If ##U(x)=U##, ##x>L## then it was logical thing to say that ##D=0##, but ##U## is just for some distance.
Arman777 said:
If U(x)=UU(x)=UU(x)=U, x>Lx>Lx>L then it was logical thing to say that D=0D=0D=0, but UUU is just for some distance.
If one is dealing with tunneling - in your situation if U(0) is less than U; effectively a barrier of height ( U - U(0) ) = V is effective and only with the condition of E < V one has to explore the tunneling process.
for calculating the tunneling probability one needs the amplitudes A and E,
the coefficients/amplitudes are A, B, C, D., E, F In The three regions
if the wave/particle is incident from left B=0 and C, D, will survive as reflection from the barrier wall and E will survive,
one can see the following reference-
<https://pdfs.semanticscholar.org/61f0/15a4466eda8a25bce28e766ffd60edd3d934.pdf>
This helpmed me a lot actually. I was so confused about the process of it and how to deal with it. Thanks a lot.
I did not understand this part. If you are talking about the article then why B should be zero its the incident wave and it should have reflective parts ?
In the article it says nothing about the D and E ( In terms of my description)
I still didnt understand..
Arman777 said:
I did not understand this part. If you are talking about the article then why B should be zero it is the incident wave and it should have reflective parts?
Actually, B will not be zero, you are right I might have made the omission as I was focussing on A and E.thanks lot
I am confused about something. You said that I can take ##V=U-U_0## in this case the potential for the second and third region is ##V## or only for the third region its ##V##.
And in the first region ##U=0## definately right?
I guess its ## U(x) = 0 (I), U(II),V(III)## But I can't be sure.
Likes drvrm
Arman777 said:
I am confused about something. You said that I can take V=U−U0V=U−U0V=U-U_0 in this case the potential for the second and third region is VVV or only for the third region its VVV.
I am looking at the tunneling process
you are right that first region has potential zero-
If one takes a potential V which is a barrier of height (U - U(0)) then for particle energy E which is less than V has a quantum probability of tunneling. the base potential is U(0) in the third region and E is greater than U(0) but less than U.
the nature of the solution is well known inside the barrier of length L or outside the barrier- as a standard solutions of Schrodinger equation.
the solution does depend on the value of E relative to the height of the barrier and only two types of wave functions either exponential decay or oscillatory is available with continuity at the boundary.
the continuity equations further relate the amplitudes and thus determines the transmission or reflection at the boundary.
FAQ: Finding the Wavefunction for Tunneling,with tunnel lenght L
1. What is tunneling in quantum mechanics?
Tunneling in quantum mechanics is the phenomenon where a particle can pass through a barrier even though it does not have enough energy to overcome the barrier. This is possible due to the probabilistic nature of particles in quantum mechanics, where there is a small chance that the particle can exist on the other side of the barrier without actually crossing it.
2. How is tunneling related to the wavefunction?
The wavefunction is a mathematical description of a particle in quantum mechanics, and it contains information about the probability of finding the particle in a certain location. In the case of tunneling, the wavefunction allows us to calculate the probability of the particle being on the other side of the barrier, even though it does not have enough energy to pass through it.
3. What is the importance of finding the wavefunction for tunneling?
Finding the wavefunction for tunneling is important because it allows us to understand and predict the behavior of particles in quantum tunneling. It also helps us to design and improve technologies that rely on tunneling, such as transistors in electronic devices.
4. How do you calculate the wavefunction for tunneling?
The wavefunction for tunneling can be calculated using Schrödinger's equation, which describes how the wavefunction evolves over time. This equation takes into account the energy and potential of the barrier, as well as the mass and position of the particle.
5. How does the tunnel length (L) affect the wavefunction for tunneling?
The tunnel length (L) is an important factor in the calculation of the wavefunction for tunneling. It determines the probability of the particle being able to tunnel through the barrier, with longer tunnel lengths resulting in a higher probability of tunneling. Additionally, the shape and height of the barrier also play a role in the calculation of the wavefunction.
