Finding the work done by a block
The discussion focuses on calculating the work done by friction on a block sliding down a rough inclined plane. The force due to gravity is determined by M * g * sin(θ), while the normal force is M * g * cos(θ). The frictional force is calculated as μ * F_normal, and the net force acting on the block is the difference between the gravitational force and the frictional force. The work done by friction is expressed as W_friction = μ * M * g * cos(θ) * (h - (1/2) * g * t^2), where h is the initial height and t is time. The discussion also clarifies the kinematic equation used to derive the distance traveled by the block.
HeavenWind
The problem is: A block with mass M is placed onto a rough inclined plane. After the block is released, it immediately begins to accelerate down the ramp due to gravity. The coefficient of friction for this ramp is μ. A stopwatch measures time t in seconds after the block is released at height h.
Derive an expression that represents the work done on the block by friction at time t in terms of t, h, θ, m, μ, and physical constants as appropriate.
F_normal = M * g * cos(θ)
F_gravity = M * g
F_friction = μ * F_normal
F_net / M
d = h - (1/2) * g * t^2.
v = √(2 * a * (h - (1/2) * g * t^2))
We want to figure out how much work friction does on a block as it slides down an inclined plane with a rough surface.
we find the force due to gravity that pulls the block down the ramp, that's found by M * g * sin(θ),
The normal force on the block is given by M * g * cos(θ).
The force of friction acting on the block is μ * F_normal
The net force acting on the block is found by subtracting the force of friction from the force due to gravity.
The acceleration of the block down the ramp is given by the net force divided by the mass of the block.
We find the velocity of the block at any given time by multiplying the acceleration by the time.
We find the distance traveled by the block at any given time by using kinematic equations.
Finally, we find the work done by friction by multiplying the force of friction by the distance traveled by the block. It's given by μ * M * g * cos(θ) * (h - (1/2) * g * t^2), where h is the initial height of the block, t is the time, and physical constants are used where appropriate.
To be more specific, here is what my friend did, not sure if it is correct:
To derive the expression for the work done on the block by friction at time t, we need to consider the forces acting on the block.
Let's assume that the inclined plane makes an angle θ with the horizontal. The force due to gravity acting on the block is given by:
F_gravity = M * g * sin(θ)
where g is the acceleration due to gravity.
The normal force acting on the block is given by:
The force of friction acting on the block is given by:
where μ is the coefficient of friction.
The net force acting on the block is the sum of the force due to gravity and the force of friction:
F_net = F_gravity - F_friction
= M * g * sin(θ) - μ * M * g * cos(θ)
= M * g * (sin(θ) - μ * cos(θ))
The acceleration of the block down the ramp is given by:
a = F_net / M
= g * (sin(θ) - μ * cos(θ))
The velocity of the block at time t is given by:
v = a * t
= g * (sin(θ) - μ * cos(θ)) * t
The distance traveled by the block at time t is given by:
The work done on the block by friction at time t is given by:
W_friction = F_friction * d
= μ * F_normal * (h - (1/2) * g * t^2)
Therefore, the expression that represents the work done on the block by friction at time t in terms of t, h, θ, m, μ, and physical constants as appropriate is:
The distance traveled is not vertical and is not due to motion with acceleration g.
Which general kinematic (SUVAT) equation is that based on? How are the terms defined in it?
Likes neilparker62
Yes - you were all good down to this point. Just use the acceleration down the slope which you had correctly worked out.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
