Esran
- 73
Newton's model of the tidal height, using two wells dug to the center of Earth (one from the North pole, one from the equator on the side of Earth facing away from the Moon), used the fact that the pressure at the bottom of the two wells should be the same. Assume water is incompressible and find the tidal height difference h due to the Moon using this model.
Pressure is force per unit area. Assume the wells have perpendicular cross-sectional area of exactly one unit area. Then pressure numerically equals (neglecting units) force. Our two wells connect at the center of Earth, so we must have [tex]\int^{x_{max}}_{0}\rho g_{x}dx=\int^{y_{max}}_{0}\rho g_{y}dy[/tex], where [tex]\rho[/tex] is the density of water and [tex]g_{x}[/tex] and [tex]g_{y}[/tex] are the gravitational fields active at x (distance from Earth's center in the direction of the North pole well mouth) and y (distance from the Earth's center in the direction of the equator well mouth), respectively.
I'm having trouble getting started, beyond what I've outlined above. I have equations for the x and y components of the tidal force. I'm assuming [tex]g_{x}[/tex] is the sum of the gravitational field induced by the Earth and the gravitational field induced by the Moon. Likewise for [tex]g_{y}[/tex]. Now, the gravitational field of the Earth should be about the same in either case, and thus cancel out, leaving the tidal forces to contend with.
Is this the right approach?
