Finding total resistance in parallel circuit
In summary: As an example of the work you did already, you had (for the 50 W bulb)I=50/110= .45 A[...]For 50 Watt lamp  R=110/.45 = 244.4 Ω@Hannah: You might be more careful with significant digits, especially early on. Continuing this example, suppose we used 5 significant figures (digits) from the beginning. Then, I=50/110= 0.45454 AAnd R = 110/0.45454 = 242.00 Ω
kriegera
74
This is a 3-part problem of which I have solved 1 and 2. I've included here just so you can follow the problem. A 50-watt lamp, a 20-watt, a 75 watt lamp, and a 100-watt lamp are connected in parallel to a 110-volt circuit. Calculate a) the current through each lamp; b) the resistance of each lamp; c) the total resistance of the circuit.
a.) Current is calculate by I=P/V where P is in Watts so 
I=50/110 = .45 A
I=20/110 = .18 A
I=75/110 = .682 A
I=100/110=.91 A
b.) Here we use Ohm’s Law again: R = V / I
For 20 Watt lamp  R=110/.18 = 611 Ω
For 75 Watt lamp  R=110/.682 = 161.29 Ω
For 100 Watt lamp  110/.91 = 120.88 Ω
c.)To find total resistance of the circuit in parallel, use
R=1/(1/244.4) + (1/611) + (1/161.29) + (1/120.88) = 49.5 Ohms
I've seen many ways to calculate resistance - but is it accurate to do it this way for a parallel circuit?
Yes, that's the method to do it. :approve:
I assume that by your equation you mean
[tex] R_{eq} = \frac{1}{\frac{1}{R_1} + \frac{1}{R_2} + \frac{1}{R_3} + \frac{1}{R_4}} [/tex]
However, you should probably go back and re-do your answers for part a and b. The precision you used (i.e. significant figures) was small for part a, then you used a higher precision for part b, based on your low-precision answers from part a. Doing so causes some of the significant figures in your answers to part b to be pretty meaningless.
Yes, that's the equation I mean. I'm a little confused - what do you mean by "significant figures" were small and "higher precision"? thanks!
I=50/110 = .45 A
Notice, you've calculated out the resistance to 4 significant digits, but the current was only calculated out to 2 significant digits.
I=50/110= 0.45454 A
It's easier to calculate the resistance by calculating [itex] R = V/I_{total} [/itex]
got it:
For 50 Watt lamp  R=110/.4545 = 242.0 Ω
For 20 Watt lamp  R=110/.1818 = 605.0 Ω
For 75 Watt lamp  R=110/.6818 = 161.3 Ω
For 100 Watt lamp  110/.9090 = 121.0 Ω
c.) To find total resistance of the circuit in parallel, use
R=1/(1/242.0) + (1/605.0) + (1/161.3) + (1/121.0) = 49.38 Ohms
THANKS!
Related to Finding total resistance in parallel circuit
1. How do you find the total resistance in a parallel circuit?
The total resistance in a parallel circuit can be found using the formula 1/Rt = 1/R1 + 1/R2 + 1/R3 + ..., where Rt is the total resistance and R1, R2, R3, etc. are the individual resistances. This formula is based on the fact that in a parallel circuit, the total resistance is always less than the smallest individual resistance.
2. What is the purpose of finding the total resistance in a parallel circuit?
Finding the total resistance in a parallel circuit allows us to calculate the total current and voltage in the circuit. This is important for ensuring that the circuit is functioning properly and that the correct amount of current is flowing through each component.
3. Can the total resistance in a parallel circuit ever be greater than the smallest individual resistance?
No, the total resistance in a parallel circuit can never be greater than the smallest individual resistance. This is because in a parallel circuit, the current is divided between multiple branches, so the overall resistance decreases.
4. Do all components in a parallel circuit have the same voltage?
No, in a parallel circuit, each component will have the same voltage as the voltage source. This is because the voltage in a parallel circuit is constant across all branches, but the current is divided between the branches.
5. How does increasing the number of components in a parallel circuit affect the total resistance?
Adding more components in a parallel circuit decreases the total resistance. This is because as the number of branches increases, the overall resistance decreases, making it easier for current to flow through the circuit.
