Finding transition temperature of Landau ferroelectric
The discussion focuses on finding the transition temperature, T'θ, of a Landau ferroelectric by minimizing the free energy F with respect to the order parameter θ and polarization P. The derived equations indicate that θ can be zero or expressed in terms of temperature T and other parameters. The challenge lies in determining T'θ when θ approaches zero, leading to a complex cubic equation that needs to be solved. A hint suggests rewriting the expression for P in terms of T'θ to facilitate finding the solution. The discussion emphasizes the mathematical complexity involved in deriving T'θ from the established relationships.
baseballfan_ny
In terms of Landau theory, a “proper ferroelectric” is completely analogous to a ferromagnet, where the order parameter is the polarization ##P## (dipole moment per volume). We can write a free energy for the ferroelectric phase transition as ##F_P = \frac 1 2 \alpha (T - T_P)P^2 + \frac 1 4 g_4 P^4 + ...##.
For a molecular crystal a structural phase transition can occur where the molecular axis tilts by an angle ##\theta## with respect to the crystal axis. The associated free energy is ##F_{\theta} = \frac 1 2 a_{\theta}(T - T_{\theta}) \theta^2 + \frac 1 4 b_{\theta} \theta^4 + ... ##.
Under certain circumstances (the molecule is chiral, i.e., lacks inversion symmetry), the dipole moment on the molecule can couple to the molecular tilt, with a coupling term ##F_{P \theta} = -t \theta P ## where t is the coupling constant.
##T_{\theta} > T_P## and a tilt phase transition will occur first on cooling. A net polarization can exist due to coupling.
a. In the tilted phase ##T_P < T < T_{\theta}##, determine ##\theta## and ##P## in terms of ##\alpha##, ##a_{\theta}##, ##b_{\theta}##, ##T_P##, and ##T_{\theta}##. You can neglect the ##P^4## term.
b. Because of the coupling, the tilt transition does not occur at ##T_{\theta}##, but some other temp ##T_{\theta}^{'}##. Determine ##T_{\theta}^{'}## and the critical exponent ##b## for order parameter ##\theta##.
##\frac {\partial F} {\partial \xi} = 0 ##
So for part a, I separately minimized F wrt ##\theta## and ##P## and got the following.
$$\frac {\partial f} {\partial \theta} = a_{\theta}(T-T_{\theta})\theta + b_{\theta}\theta^3 - tP = 0$$
$$ \frac {\partial f} {\partial P} = \alpha(T-T_P)P -t\theta$$
$$ P = t\theta \alpha (T-T_P) $$
Then subbing this into the expression for θ gives me...
$$ \theta \left[ a_{\theta}(T-T_{\theta}) + b_{\theta}\theta^2 - t^2\alpha(T-T_P) \right] = 0 $$
which I can solve for ##\theta = 0## or ##\theta = \sqrt {\frac {t^2} { \alpha (T - T_P) } }- a_{\theta}(T - T_{\theta})##. And plugging this in gives ##P = \pm \frac {t} {\alpha (T - T_P)} \sqrt {\frac {t^2} { \alpha (T - T_P) } }- a_{\theta}(T - T_{\theta})##.
Now my problem is with b, because I don't think I have the proper approach of finding the temperature at which the phase transition occurs, ##T_{\theta}^{'}##. My idea was that maybe ##T_{\theta}^{'}## is the temperature ##T## when ##\theta## goes to 0.
That is
$$\pm \sqrt {\frac {t^2} { \alpha (T_{\theta}^{'} - T_P) } }- a_{\theta}(T_{\theta}^{'} - T_{\theta}) = 0 $$
$$ \frac {t^2} { \alpha (T_{\theta}^{'} - T_P) } = (T_{\theta}^{'} - T_{\theta})(T_{\theta}^{'} - T_P) $$
which seems a bit difficult to solve for ##T_{\theta}^{'}##. The hint I have from class is that I should somehow re-write the expression for P in terms of ##T_{\theta}^{'}##.
It is a cubic equation of ##T'_{\theta}## whose solution we know by formula.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
