- #36
Baluncore
2023 Award
- 14,865
- 8,737
Three other ways.
1. Mark your exact location on a map. Look for a distant visible feature that is also marked on the map. Draw a line on the map between the two. Rotate the map so the line points at the distant feature. The map is then correctly orientated, so the map grid will be N–S at your location.
2. Use a GPS to read Lat–Long on site and somewhere that can be seen from site. Travel back and forth to check the readings are reliable. The bearing of the line between the two sites can be found from the equations for a great circle passing through those two points.
3. If you read GPS Longitude, then find a place North or South with exactly the same longitude, the line between the two will be true North–South. The further apart the points, and the more times you check the numbers, the more accurate the N–S line.
