Finding Two Wave's Common Amplitude
  • Thread starter foundAnAnswer
  • Tags
    Amplitude
In summary, the given equation represents two identical sinusoidal waves traveling in the same direction along a string. The wavelength of the waves is 0.35 meters and the phase difference between them is 1.92 radians. The amplitude of the waves is 0.8726 mm.
foundAnAnswer
Two sinusoidal waves, identical except for phase, travel in the same direction along a string producing a net wave y'(x, t) = (1.0 mm) sin(18x - 4.0t + 0.960 rad), with x in meters and t in seconds.
(a) What is the wavelength λ of the two waves?
(b) What is the phase difference between them?
(c) What is their amplitude ym?
I got A and B correct with answers of 0.35 and 1.92
y'm = 2ym cos([tex]\frac{\Phi}{2}[/tex])
I set y'm = 1 mm and [tex]\frac{\Phi}{2}[/tex] = 0.96
Then
[tex]\frac{1}{2cos(.96)}[/tex] = ym
0.5 = ym (Rounding)
Not sure what I'm doing wrong.
Any help is appreciated.
Thanks!
I found my answer. I took the given equation and set it equal to the sum equation.
I then set x and t to zero and solved for ym
That led to
[tex]\frac{sin(\frac{\Phi}{2})}{sin(\Phi)}[/tex]
In this case
[tex]\frac{sin(.96)}{sin(1.92)}[/tex] = ym = .872
Your approach is correct, but there is a small error in your calculation. When dividing by cos(0.96), you should use the inverse cosine function (cos^-1) rather than just 0.96. So the correct calculation would be:
ym = 1 mm / (2cos^-1(0.96)) = 0.50 mm
So the amplitude of both waves is 0.50 mm.
Hope this helps!
FAQ: Finding Two Wave's Common Amplitude
What is the common amplitude of two waves?
The common amplitude of two waves is the maximum displacement from the equilibrium position, or the highest point of the wave, that is shared by both waves.
Why is finding the common amplitude of two waves important?
Knowing the common amplitude of two waves is important because it helps us understand how the waves will interact with each other and how they will affect the resulting wave.
How do you find the common amplitude of two waves?
To find the common amplitude of two waves, you need to graph the waves and identify the highest point that both waves reach. This point will be the common amplitude.
Can the common amplitude of two waves be negative?
Yes, the common amplitude of two waves can be negative. This means that the waves are out of phase and will cancel each other out at certain points.
Is it possible for two waves to have more than one common amplitude?
No, two waves can only have one common amplitude. This is because amplitude is a measurement of the maximum displacement, and there can only be one highest point on a wave.
