Finding unitary operator associated with a given Hamiltonian
The discussion focuses on finding the unitary operator associated with a given Hamiltonian, specifically using the Pauli matrix ##\sigma_1##. The unitary operator is expressed as ##U(t) = \exp(-i \omega \sigma_1 t)##, which is easily computed when the Hamiltonian is diagonalized. The challenge arises when attempting to convert ##U(t)## back to the original basis ##\{|0\rangle, |1\rangle\}##, as the initial calculations yield an incorrect representation. Suggestions include expressing the eigenstates in terms of the original basis and utilizing properties of the Pauli matrix to simplify the process. The conversation emphasizes the importance of correctly computing the matrix elements to achieve accurate results.
ubergewehr273
Given a Hamiltonian ##H = \hbar \omega \sigma_1##, you are supposed to find the associated time-evolution unitary operator ##U(t)##.
Time-independent Schrodinger's equation
$$-i \hbar \frac{\partial | \psi (t) \rangle}{\partial t} = \hat{H} | \psi (t) \rangle$$
The associated unitary operator is
$$U(t) = \exp (\frac{-i \hat{H} t}{\hbar})$$
Now from the relevant equations,
$$U(t) = \exp(-i \omega \sigma_1 t)$$
which is easy to compute provided the Hamiltonian is diagonalized. Writing ##\sigma_1## in its eigenbasis, we get
$$\sigma_1 =
\begin{pmatrix}
1 & 0\\
0 & -1\\
\end{pmatrix}
and hence the unitary ##U(t)## becomes
$$U(t) =
\begin{pmatrix}
e^{-i \omega t} & 0\\
0 & e^{i \omega t}\\
\end{pmatrix}
Mind you that the above representation of $U(t)$ is in the basis ##\{ |+\rangle, |-\rangle\}## where
$$ |+\rangle =
\frac{1}{\sqrt{2}}
\begin{pmatrix}
1\\
1\\
\end{pmatrix}
$$ |-\rangle =
\frac{1}{\sqrt{2}}
\begin{pmatrix}
1\\
-1\\
\end{pmatrix}
Now, I need to write ##U(t)## back in the original basis ##\{|0\rangle, |1\rangle\}## (which is where I'm facing an issue). Finding the components of the above expression for ##U(t)## in the original basis,
$$\langle 0 | U(t) | 0 \rangle = e^{-i \omega t} \qquad \langle 1 | U(t) | 1 \rangle = e^{i \omega t}$$
with ##\langle 0 | U(t) | 1 \rangle = 0## and ##\langle 1 | U(t) | 0 \rangle = 0##. This gives me the exact same matrix representation in the original basis. Obviously this is not true and I'm doing something wrong.
For inline Latex you need to use double hashes rather than single dollars.
You'll have to show your work, for instance ##\langle 0 | U(t) | 0 \rangle##, because the result you get is incorrect.
You can write your solution in terms of
$$\hat{U}=\exp(-\mathrm{i} \omega t) |+ \rangle \langle +| + \exp(\mathrm{i} \omega t) |- \rangle \langle -|.$$
Now simply express ##|+ \rangle## and ##|- \rangle## as linear combinations of ##|1 \rangle## and ##|0 \rangle## and multiply out the dyadic products. Then you can read out the matrix elements easily.
A much easier way is to directly use the properties of the Pauli matrix. All you need is ##\hat{\sigma}_1^2=1## and then write down the power series for the exponential function.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
