Finding unknown substances and masses
  • Thread starter 00_Furon
In summary: H.42.5 g O / 16.00 g/mol = 2.66 mol of O.c. To calculate the mass of substance C formed, we first need to determine the limiting reagent. From our calculations in part a and b, we can see that substance B has a smaller number of moles than substance A. This means that substance B is the limiting reagent and will be completely consumed in the reaction.Next, we can use the given information that 10.0 g of substance C, when burned in excess oxygen, produces 33.8 g of CO2 and 6.92 g of H2O. From this, we can calculate
00_Furon
From the information below, determine the mass of substance C that is formed if 45.0 g of substance A reacts with 23.0 g of substance B, assuming that the reaction between A and B goes to completion.
a. Substance A is a gray solid that consists of an alkaline Earth element and carbon; the m% carbon in the compound is 37.5%. It reacts with substance B to form substances C and D. 4.0 x 1016 formula units of compound A weighs 4.26 micrograms.
b. 47.9 g of substance B contains 5.36 g H and 42.5 g O.
c. When 10.0 g of substance C is burned in excess oxygen, 33.8 g of CO2 and 6.92 g of H2O are produced. The molar mass of substance C is MC = ~26 g/mol.
d. Substance D is the hydroxide of the metal in substance A.
To determine the mass of substance C formed in the reaction, we need to use the given information to calculate the number of moles of substance A and B, and then determine the limiting reagent. The limiting reagent is the substance that will be completely consumed in the reaction, and therefore determines the amount of product formed.
a. To calculate the number of moles of substance A, we first need to convert the given mass of 4.0 x 1016 formula units to moles. We can do this by using the molar mass of substance A, which can be calculated using the given information about its composition. Substance A consists of 37.5% carbon, which means that the remaining 62.5% must be the alkaline Earth element. This gives us a molar mass of (0.375 x 12.01 g/mol) + (0.625 x atomic mass of alkaline Earth element g/mol).
Now, we can use the given information that 4.0 x 1016 formula units of substance A weighs 4.26 micrograms to calculate the molar mass of substance A. This gives us a molar mass of 4.26 micrograms / (4.0 x 1016) = 1.065 x 10^-20 g/mol. Converting this to grams/mol gives us a molar mass of 1.065 x 10^-23 g/mol.
Next, we can use the given mass of 45.0 g of substance A to calculate the number of moles of substance A:
45.0 g / (1.065 x 10^-23 g/mol) = 4.22 x 10^23 mol of substance A.
Similarly, we can calculate the number of moles of substance B using its given mass of 23.0 g and its molar mass of 47.9 g/mol:
23.0 g / 47.9 g/mol = 0.481 mol of substance B.
b. From the given information, we can determine that 47.9 g of substance B contains 5.36 g of hydrogen and 42.5 g of oxygen. Using the molar masses of hydrogen (1.008 g/mol) and oxygen (16.00 g/mol), we can calculate the number of moles of each element present in 47.9 g of substance B:
5.36 g H / 1
Related to Finding unknown substances and masses
1. How do you identify unknown substances and masses?
There are several methods for identifying unknown substances and masses. These include spectroscopy, chromatography, and mass spectrometry. Each method involves analyzing the physical and chemical properties of the substance or mass and comparing it to known standards or databases to determine its identity.
2. What equipment is needed for finding unknown substances and masses?
The equipment needed for finding unknown substances and masses varies depending on the method used. Some common equipment includes spectrometers, chromatography columns, and mass spectrometers. In addition, specialized software and databases may also be used for data analysis and comparison.
3. What is the importance of finding unknown substances and masses?
Identifying unknown substances and masses is important for a variety of reasons. It can help with product quality control, environmental monitoring, and forensic investigations. Additionally, knowing the identity of a substance or mass can also provide valuable information about its properties and potential uses.
4. How accurate are the results of finding unknown substances and masses?
The accuracy of the results depends on the method used and the expertise of the scientist performing the analysis. Spectroscopy and chromatography are highly accurate methods, while mass spectrometry can have some margin of error. It is important for scientists to carefully calibrate their equipment and use proper techniques to ensure accurate results.
5. Can substances and masses be completely unidentified?
In some cases, substances and masses may not be able to be completely identified. This may be due to a lack of reference standards or a complex mixture of substances. In these cases, scientists may use a combination of methods and data analysis to make an educated guess about the identity of the unknown substance or mass.
21K
10K
21K
