Finding values for a and b for this polynomial
  • Thread starter chef99
  • Tags
    Polynomial
In summary: And for f(-2) = -560f(-2) = (1162/641)(-2)4 - 3(-2)3- 63(-2)2+ 152(-2) - (644/641) = -561.55I have no idea what I am doing wrong.In summary, the polynomial f(x) = ax4 - 3x3- 63x2+ 152x -
chef99
75
the polynomial f(x) = ax4 - 3x3- 63x2+ 152x - b
has one of its zeros at x = 5 and passes through the point (-2, -560)
Question: Use this info to find the values of a and b
I am prepping for a test and this one question is really stumping me, I wondered if anyone would be able to help. For all of this type of question up till now where it asks to find a and b, I have been given a factor and the remainder. I know with these values I should set up two equations, one for a and one for b, then use them to solve each other. I know if a zero is x = 5 then a factor will be x = -5 but I have no idea what to do with the point given, is there something obvious I am missing? Any help on this would be greatly appreciated
[Moderator's note: Moved from a technical forum and thus no template.]
So the fact that it has a zero when x=5 means the point (5,0) is on the curve.
Plugging those in gives you equation in two unknowns a and b right?
What happens when you plug in the other point?
You get second equation in two unknowns a and b again.
Given that what is a and b?
Likes symbolipoint
jedishrfu said:
o the fact that it has zeros when x=5 means the point (0,5) is on the curve
No, it means that (5, 0) is on the curve.
The rest of the hint is fine.
Likes jedishrfu
You saw my post before I edited it. I had a dyslexic moment and then saw my mistake.
Likes symbolipoint
Thank you for your help.
Ok so for the first equation (x-5) --> remainder is 0, so f(-5) = 0
and for the second equation (x+2) --> remainder of -560
Is that correct? I have tried following this and using the two equations to solve for the variables in each other but when I try to test it afterword, with my values of a and b f(-5) should = 0, but I am not getting zero as a value so either there is an error in my calculations or I am applying your advice incorrectly. I have included my work below.
(x-5) --> remainder is 0 so f(-5) = 0 f(x) = a(-5)4 - 3(-5)3- 63(-5)2+ 152(-5) - b
-625a -(-375)-1575-760 - b = 0
-625 - 2710 - b = 0
-625a - b = 2710Now for the second equation;
(-2, -560) is a point so (x + 2) --> remainder of -560
a(2)4 - 3(2)3- 63(2)2+ 152(2) - b = -560
16a - 24 - 252 + 304 - b = -560
16a + 28 - b = -560
16a +588 = bNow plugging 16a +588 = b into the first equation,
-625a - 16a +588 = 2710
a = 2710/-609finally, solve for b,
16a +588 = b
16(2710/-609) +588 = b
b = 516.8Checking for f(-5) = 0,
f(-5) = (2710/-609)(-5)4 - 3(-5)3- 63(-5)2+ 152(-5) - 516.8= -5248
As you can see this is obviously not right as it should equal 0. Am I just making errors in my calculations or do I have the wrong idea entirely?
No that's not how to do it:
## f(5) = 0 ##
##0 = a(5)^4 - 3(5)^3- 63(5)^2+ 152(5) - b ##
The other point has the same sign error.
It is (x,y)=(-2, -560), you have to plug in -2 for x.
## f(5) = 0 ##
I have fixed this error, and the one pointed out by mfb, using f(5) remainder of 0 and f(-2) remainder of -560 but am still not getting f(5) = 0 when testing it afterward. I also keep getting fraction/decimal numbers, is that to be expected or should I be getting whole numbers? Perhaps I am screwing up the process later?
Here is what I got:
f(x) = a(5)4 - 3(5)3- 63(5)2+ 152(5) - b
625a -375-1575+760 - b = 0
625 - 1190 - b = 0
625a - b = 1190
and
a(-2)4 - 3(-2)3- 63(-2)2+ 152(-2) - b = -560
-16a + 24 - 252 - 304 - b = -560
-16a -532 - b = -560
b = -16a + 28
then using this value for b, -16a + 28, determine a:
625a - b = 1190
625a - (-16a + 28) = 1190
641a = 1162
a = 1162/641 <--- as you can see I'm getting a fraction, don't know if that's wrongUsing this to find b:
b = -16a + 28
b = -16(1162/641) + 28
b = -18592/641 + 28
b = 644/641Then when I test these values for a and b to see if f(5) = 0,
f(5) = (1162/641)(5)4 - 3(5)3- 63(5)2+ 152(5) - (644/641)
f(5) = - 37184/641
f(5) = -58
This is obviously not right but I don't know where I'm messing up. Am I using the correct method to find a and b or is it arithmetic error I'm making?
You have some sign errors.
In particular, ##(-2)^4 \ne -16 ## .
Related to Finding values for a and b for this polynomial
1. How do I find the values for a and b in a polynomial equation?
The values for a and b in a polynomial equation can be found by using a process called polynomial regression. This involves collecting data points, plotting them on a graph, and then using mathematical techniques to find the best fit line or curve for the data. The values for a and b can then be determined from this best fit line or curve.
2. What is the significance of a and b in a polynomial equation?
The values for a and b in a polynomial equation play a crucial role in determining the shape and behavior of the graph of the equation. The value of a determines the vertical stretch or compression of the graph, while the value of b determines the horizontal shift of the graph.
3. Can I use any method to find the values for a and b in a polynomial equation?
While there are multiple methods for finding the values for a and b in a polynomial equation, the most commonly used method is polynomial regression. This method is based on statistical techniques and is generally considered the most accurate way to determine the values for a and b.
4. Are there any specific steps I need to follow to find the values for a and b in a polynomial equation?
Yes, to find the values for a and b in a polynomial equation, you will need to follow a specific set of steps. These include collecting data points, plotting them on a graph, finding the best fit line or curve, and then using mathematical techniques such as least squares regression to determine the values for a and b.
5. Are there any tools or software that can help me find the values for a and b in a polynomial equation?
Yes, there are many tools and software available that can assist in finding the values for a and b in a polynomial equation. Some popular options include Microsoft Excel, Wolfram Alpha, and various statistical software packages such as SPSS or SAS. It is important to choose a tool or software that is appropriate for your specific needs and level of expertise.
