Finding values for which a function is greater that 0
  • MHB
  • Thread starter tmt1
  • Tags
    Function
In summary, a function is considered greater than 0 when its output or value is higher than 0 and its graph lies above the x-axis. To graph a function and determine its intervals where it is greater than 0, points can be plotted and connected with a smooth curve, or a graphing calculator or online tool can be used. A function can be greater than 0 for all values of x, meaning it always has a positive output and never crosses the x-axis. To algebraically find these values, the function can be set equal to 0 and solved for x, or the discriminant of a quadratic function can be used. Finding values for which a function is greater than 0 is important in understanding its behavior, predicting
tmt1
234
I have a function
$$g(x) = \frac{x - 1}{x + 2}$$.
How would I find all of the x-values for which $g(x) > 0$.
I'm used to doing this for functions that need to be factored but not fractions.
Mathematics news on Phys.org
tmt said:
I have a function
There are other was, but this one is fairly standard for polynomial fractions.
There are two critical points here: when the numerator is 0 and when the denominator is 0. So the critical points are at x = 1 and x = -2. Now you have three intervals to test: \(\displaystyle ( -\infty , -2 ) \), \(\displaystyle ( -2, 1)\), and \(\displaystyle (1, \infty)\). See which of these are greater than 0.
-Dan
A fraction is positive if and only if the numerator and denominator have the same sign.
\(\displaystyle \frac{x- 1}{x+ 2}> 0\) if and only if either
1) x-1> 0 and x+ 2> 0. The first inequality gives x> 1 and the second gives x> -2. They will both be true for x> 1.
2) x-1< 0 and x+ 2< 0. The first inequality gives x< 1 and the second x< -2. They will both be true when x< - 2.
The fraction is positive when x< -2, is not defined at x= -2, is negative when -2< x< 2, is 0 when x= 1, and is positive again when x> 1.
FAQ: Finding values for which a function is greater that 0
What is the definition of a function being greater than 0?
A function is considered to be greater than 0 when its output or value is higher than 0. This means that the graph of the function will lie above the x-axis and not intersect or touch it at any point.
How do you graph a function to determine where it is greater than 0?
To graph a function and determine where it is greater than 0, you can plot multiple points on the coordinate plane and connect them with a smooth curve. Then, you can check where the curve lies in relation to the x-axis. If it is above the x-axis, then the function is greater than 0 in that interval. You can also use a graphing calculator or online graphing tool to easily visualize the function and its intervals where it is greater than 0.
Can a function be greater than 0 for all values of x?
Yes, a function can be greater than 0 for all values of x. This means that the function will always have a positive output and never cross or touch the x-axis. An example of this type of function is y = x + 1, where the output will always be greater than 0 for any value of x.
How can you algebraically find values for which a function is greater than 0?
To algebraically find values for which a function is greater than 0, you can set the function equal to 0 and solve for x. This will give you the x-intercepts of the function, which are the points where the function crosses the x-axis. The intervals between these x-intercepts will be where the function is greater than 0. You can also use the discriminant of a quadratic function to determine the number of x-intercepts and whether the function is greater than 0 for all values of x.
Why is it important to find values for which a function is greater than 0?
It is important to find values for which a function is greater than 0 because it can provide valuable information about the behavior of the function. For example, if a function is greater than 0 for all values of x, it means that the function is always increasing. This can be useful in many applications, such as in economics or physics, to understand and predict trends and patterns. Additionally, finding these values can help in determining the domain and range of the function, as well as its critical points.
