realism877
- 80
(4x+1)/(3x-4)=4.5
4<(4x+1)/(3x-4)<5
What do I have to do next?
Mark44 said:You need to figure out how big the interval centered around x = 2 needs to be so that every value of x in this interval satisfies this inequality, 4<(4x+1)/(3x-4)<5. IOW, you need to find a number δ so that if x is in (2 - δ, 2 + δ), then 4.5 - ε<(4x+1)/(3x-4)< 4.5 + ε, where ε = .5
With a graphing calculator, this should be fairly easy to do.
BTW, this is the same problem you posted in this thread - https://www.physicsforums.com/showthread.php?t=499392. Why are you starting a new thread for the same problem?
Mark44 said:.09 works for me. Good job!
The value of delta is typically determined by using mathematical calculations and considering the specific conditions of the problem. It may involve manipulating equations or using logical reasoning to find a suitable value that ensures the desired relationship between delta and epsilon.
Yes, delta can have multiple values for the same epsilon. This is because there may be various acceptable values that satisfy the desired relationship between delta and epsilon. It is important to choose a value that is the most appropriate for the given problem.
The values of delta and epsilon are used to define the concept of a limit in calculus. By finding values of delta that correspond to epsilon, we are able to determine the behavior of a function at a specific point and its relationship to the function's limit.
To check if your calculated value of delta is correct, you can plug it back into the original equation and see if the resulting epsilon is within the desired range. You can also use mathematical proofs or simulations to verify the validity of your calculated value.
Some common methods for finding values of delta that correspond to epsilon include using the definition of a limit, using algebraic manipulations, and using geometric interpretations such as graphs and geometric constructions. It is important to choose a method that is appropriate for the given problem and yields a precise and accurate value of delta.
