Finding vectors parallel to a given vector
The discussion revolves around confusion regarding the representation of parallel vectors in a problem, specifically why the answers provided are unit vectors, ##(\frac{2}{\sqrt{13}}, \frac{3}{\sqrt{13}})## and ##(-\frac{2}{\sqrt{13}}, -\frac{3}{\sqrt{13}})##, instead of the expected vectors ##(2,3)## and ##(-2,-3)##. It is clarified that the problem did not ask for unit vectors, leading to the conclusion that the published answers are incorrect. Participants also express confusion over the notation used, particularly the combination of an arrow and a caret, which is considered unusual. The conversation concludes with confirmation that the lecturer's solution was indeed the only one provided, with no missing information. The issue highlights the importance of clarity in mathematical notation and problem requirements.
member 731016
Please see below
Coordinate form of vector
For (b) of this problem,
The solution is,
However, I am confused why the two parallel vectors are ##(\frac{2}{\sqrt{13}}, \frac{3}{\sqrt{13}})## and ## (-\frac{2}{\sqrt{13}}, -\frac{3}{\sqrt{13}}) ## should it not be ##(2,3)## and ##(-2,-3)##. Do somebody please know why they wrote that?
Also I am very confused with this notation
Many thanks!
You are correct. The length of ##\overrightarrow {PQ}## is ##\sqrt {13}##, so they gave a unit vector as the answer. Their notation appears to mean the unit vector in that direction. That is not what the problem asked for.
Likes member 731016
Did the published answer to the question give ##(\frac{2}{\sqrt{13}}## and ## \frac{3}{\sqrt{13}})## as the answers? If so, these answers are wrong as they did not ask for the vectors to be unit vectors.
The other thing you asked about, PQ with both an arrow above it and a caret (or hat, for a unit vector), is unusual notation, in my experience. Usually, one or the other is used, but not both.
Likes member 731016
The only vectors which are parallel to a given vector and which are of the same length as that vector are that vector itself and its negative.
Likes member 731016 and malawi_glenn
I wonder if the answer was cut off and the unit vectors were multiplied in the final step that is not shown?
Likes member 731016
Thank you for your replies @Mark44, @pasmith and @FactChecker !
No @Mark44 that is was the only the solution published by the lecturer.
I checked the solution again @FactChecker, and nothing was cut-off, it was just the answer to part (c) of the question.
Many thanks!
