Finding velocity for projectile given distances and launch angle
The discussion focuses on calculating the velocity of a projectile, specifically a cat shot from a cannon over a wall, using the equations of motion. The original poster attempts to derive the velocity using time and distance formulas but arrives at an incorrect result of 103 m/s instead of the expected 54 m/s. Participants highlight confusion over the use of angles, particularly the incorrect reference to cos(3025), and suggest deriving the expression for velocity algebraically before substituting numerical values. They emphasize the importance of correctly applying trigonometric functions and clarifying the parameters involved in the calculations. Overall, the conversation aims to clarify the mathematical approach to solving projectile motion problems.
aqryus
A cat is shot out of a cannon over a 30m high wall at an angle of 55 degrees from ground level. With what speed does it have to be launched to make it approximately 5m lover the wall if the wall is 250m from the cannon?
t =d/v
d = (v) (t) + (0.5) (a) (t)^2
i used t=d/v for the x direction using the formula t=250/vcos55
and subbed that into the formula for the y direction
35 = (vsin55) (250/vcos55) - (4.9) (250/vcos55)^2
canceled out the first two v
35 = sin55 (250/cos55) - (306250/v^2cos3025)
35 = 357 - (306250/v^2cos3025)
35 cos3025 (v^2) = 306250
v^2 = 306250/25cos3025
v^2 = 10669
v = 103 m/s
but the answer is 54m/s so this is way off and I'm really not sure what I'm doing wrong. I thought maybe I should use 500m for x distance because the cat reaches 35m at the wall, which is only half of the trajectory (?). Any help is appreciated thank you.
aqryus said:
Homework Statement:: A cat is shot out of a cannon over a 30m high wall at an angle of 55 degrees from ground level.
Oh noes! A cat? Are you sure it wasn't a car or a rat? Poor kitty! :oops:
  • Haha
Likes PeroK, Mark44 and erobz
I can only speak for myself when I say that I could be more helpful if understood your numbers and how you got them. I am baffled by equations like
Do you really mean cos3025? Where did you get an angle equal to 3025 in , I assume, radians?
I strongly recommend that you work out the solution algebraically without using numbers to get an expression for ##v^2## in terms of the projection angle ##\theta##, the horizontal distance ##x##, the wall height ##h## and, of course, ##g##. Then substitute the numbers. This would help us figure out (a) whether you got the wrong expression and where you went wrong or (b) whether you made a mistake in substituting the numerical values.
Likes berkeman and erobz
It doesn't work this way. ##(v\cos(55))^2## is ##v^2 (\cos(55))^2##, with the cosine factor commonly written as ##\cos^2(55)##. The idea is that you're supposed to calculate ##\cos(55)## and then square that number, not square 55 and take the cosine of 3025.
Really, fire a cat out of a cannon? That's weird...
Likes berkeman and PeroK
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
