Finding Velocity When Only Given Height
In summary, a football is kicked from a height of 2 meters, and the initial velocity and time taken to reach the maximum height can be calculated using the following equations: v=d/t and u=Sin(k).
akb16
A football is kicked from a height of 2.0m to a maximum height of 8.0m. Calculate the football's initial velocity and the time taken to reach the maximum height.
v=d/t
I have no idea how to even approach this question. How do I apply formulas to solve this question given only the height of the football??
What formulas describe the velocity and position of a projectile? (I would assume the football moves vertically.)
the dispalcement is 6 metres and the final velocity is zero and the acceleration due to gravity is -g(-9.81) so use suvat equation V(squared)=U(squared) + 2AS
Either do I, with the information you're given.
Since footballs are generally not kicked straight up, they follow a parabolic path. Without knowing the horizontal distance from the point where it was kicked to the point where it reached it's peak height, you cannot come up with a definitive answer.
Wow! The kicker must be a giant!
@zgozvrm , the question is valid and the answer can be found just by using the two equations of constant acceleration
s=ut+0.5at^2
v^2 - u^2 = 2as
remember to only use the part of the ball's motion from the start t=0s to the time at which it reaches it's max hieght...
another thing that we will have to assume constant verticle acceleration for this question (which in practise is not)
The problem can't be solved unless you consider the motion to be ONLY vertical, in that case [itex] V^2 - V{_0}^2 = 2as [/itex] looks pretty good :)
^^agreed
assuming the ball is thrown vertically upwards and neglecting air resistance, it can be solved
cheers
correct me if i am wrong, i think the problem can be solved if we have just on more quantity ... ie the angle at which the ball was kicked ... (the angle to the horizontal)
thus the initial velocity would be having two components (one in the x direction the other in the y direction) and the y component will be
u*Sin(k)
That is correct.
Like I said before, you need more information in order to solve the problem; like angle or distance kicked. Or, perhaps, the football's velocity as it hit the ground (which will differ from the initial velocity since it was kicked from a height of 2 meters!).
FAQ: Finding Velocity When Only Given Height
What is the equation for finding velocity when only given height?
The equation for finding velocity when only given height is V = sqrt(2gh), where V is the velocity, g is the acceleration due to gravity (usually 9.8 m/s^2), and h is the height.
What units should be used for the height and velocity in the equation?
The height should be measured in meters (m) and the velocity will be in meters per second (m/s).
Can this equation be used for any object dropped from a height?
Yes, this equation can be used for any object dropped from a height as long as the object is in a vacuum or air resistance is negligible. It is also important to note that the object is not being thrown or propelled upwards, only dropped from a height.
What if the height is given in feet instead of meters?
If the height is given in feet, it will need to be converted to meters before using the equation. 1 foot is equal to 0.3048 meters, so the height in feet must be multiplied by 0.3048 to get the height in meters.
Is there a way to calculate the initial velocity if the time is also given?
Yes, if the time is also given, the initial velocity can be calculated using the equation V = gt, where V is the velocity, g is the acceleration due to gravity, and t is the time.
