Finding Velocity with Kinetic Energy.
The work done by the force of 30 N is equal to the change in potential energy, which is equal to the change in kinetic energy.In summary, the problem involves a toy rocket with a mass of 250 g being propelled by a 30N thrust engine until it reaches a height of 165 m. The goal is to find the velocity of the rocket at that height using energy conservation. The first attempt involved finding the acceleration and using it in the kinetic energy formula, but the teacher suggested using the law of conservation instead. To find the work done by the force of 30 N in moving the rocket 165 m, one must take into account gravity and equate it to the change in potential and kinetic energy.
kencamarador
33
I have to use energy conservation to solve this. So i cannot solve with kinematics
"On a windless day, the engine of a 250 g toy rocket exerts 30N of thrust straight upward until it burns out at a height of 165 m"
How fast is the rocket moving at 165m?
Ek=mv^2 / 2
Em=eg+ek
Eg=mgh
First i found my acceleration.
A= f/m
A= (30- 9.8 x .25) / 0.25
=110.2
Then subbed into
Vf^2 = 0 + 2(110.2)x165
190.1
But my teacher told us to use the law of conservation...
Well the work done in moving the rocket 165 m will be equal to the kinetic energy of the rocket at 165 m.
How would you find the work done by the force of 30 N in moving 165 m?
Mutliply 30 by 165 which is 4950
oh... Then solve for v
You need to take into account gravity.
I would like to clarify that the approach of using energy conservation to solve this problem is valid and can provide accurate results. The equations used are correct and the calculation of acceleration is also accurate. However, using kinematics equations would also be a valid approach to solve this problem.
Kinematics and energy conservation are two different approaches to solving problems in physics. While kinematics deals with the motion of objects and their position, energy conservation deals with the transfer and transformation of energy within a system. Both approaches can provide valuable insights and solutions to different problems.
In this specific problem, using energy conservation allows us to consider the energy changes within the rocket as it moves upwards. This approach takes into account the work done by the engine (30N of thrust) and the potential energy gained by the rocket due to its position at a certain height. Using the equations provided, we can accurately calculate the final velocity of the rocket at 165m.
On the other hand, using kinematics equations would involve considering the initial velocity of the rocket, the acceleration due to gravity, and the displacement. This approach would also provide an accurate solution to the problem.
In conclusion, as a scientist, it is important to understand and be familiar with different approaches to solving problems in physics. Both energy conservation and kinematics are valid methods and can be used to solve this problem.
FAQ: Finding Velocity with Kinetic Energy.
What is kinetic energy?
Kinetic energy is the energy an object possesses due to its motion. It is a form of energy that is related to an object's mass and velocity.
How is kinetic energy related to velocity?
Kinetic energy is directly proportional to an object's velocity. This means that as an object's velocity increases, its kinetic energy also increases.
How do you calculate kinetic energy?
The formula for calculating kinetic energy is KE = 1/2 * m * v^2, where m is the mass of the object and v is its velocity.
What is the difference between kinetic energy and velocity?
Kinetic energy is a measure of an object's energy due to its motion, while velocity is a measure of an object's speed and direction of motion.
Why is kinetic energy important in finding velocity?
Kinetic energy can be used in conjunction with other variables, such as mass, to calculate an object's velocity. This is useful in many scientific fields, including physics and engineering.
