Finding x and y components of velocity?
In summary, the conversation discusses a soccer player kicking a ball at an angle above the horizontal and the ball's motion in the air for 3.0 seconds, landing 40 m away assuming a level field. The conversation then goes on to make a table of x and y components and find the initial horizontal and vertical velocity components of the ball. The correct answer for part b) is 13.3m/s, while for part c) it is incorrect and should be -29.4m/s. The missing angle does not need to be found.
santoki
34
Question:
A soccer player kicks the ball off the ground at an angle Θ above the horizontal. The ball is in the air for 3.0 seconds and lands 40 m away (assume the field is level).
a) Make a table of x and y components and fill out what you know, based on the problem statement above, and your knowledge of kinematics (don’t calculate anything yet). Draw a box around your table.
b) Now work outside of the box. Find the soccer ball’s initial horizontal (vox) velocity component.
c) Find the soccer ball’s initial vertical (voy) velocity component.
Attempt:
a)
x-component
  • d = 40m
  • t = 3s
  • vo = 0m/s
  • a = 0m/s2
y-component
  • a = 9.8m/s2
  • t = 3s
  • v = 0m/s
b)
d = vt
40 = 3v
v = 13.3m/s
c)
v = vo - gt
v = 0 - (9.8)(3)
v = -29.4m/s
am I on the right track or am I supposed to find that missing angle?
Time t=0 starts the moment that the ball loses contact with the player's boot. So neither of the ##V_0## terms is zero.
Likes 1 person
yeah. I agree with Nascent. In this kind of situation, you're only concerned with the motion of the ball immediately after it has been kicked. That is why you are able to say a=0 for the horizontal acceleration. You have used this fact for part b) since the formula d=vt assumes zero acceleration. p.s. you have the right answer for part b)
For part c), it's not quite right. Remember you are supposed to find the initial vertical velocity (immediately after the ball has left the player's boot, so it's not going to be zero). Also, you don't need to find the missing angle, but you could do it that way if it makes more sense to you.
Likes 1 person
Related to Finding x and y components of velocity?
1. What are the x and y components of velocity?
The x and y components of velocity represent the horizontal and vertical parts of an object's motion. The x component is the velocity in the horizontal direction, while the y component is the velocity in the vertical direction.
2. How do you find the x and y components of velocity?
The x and y components of velocity can be found using trigonometric functions, specifically the sine and cosine functions. The x component is equal to the total velocity multiplied by the cosine of the angle of motion, and the y component is equal to the total velocity multiplied by the sine of the angle of motion.
3. Why do we need to find the x and y components of velocity?
Finding the x and y components of velocity allows us to analyze an object's motion in two dimensions. This is useful for understanding the direction and speed of an object's motion, as well as predicting its future path.
4. Can the x and y components of velocity be negative?
Yes, the x and y components of velocity can be negative. A negative x component indicates motion in the negative horizontal direction, while a negative y component indicates motion in the negative vertical direction. This is important to consider when analyzing an object's motion and calculating its total velocity.
5. How do the x and y components of velocity relate to the total velocity?
The x and y components of velocity, when squared and added together, equal the square of the total velocity. This is known as the Pythagorean theorem and is a useful relationship to remember when working with vector components.
