MHB *finding zero of order 4 polynominial
  • Thread starter Thread starter karush
    Zero
To find the zeros of the polynomial function f(x) = 16x^4 + 3x^2 - 2, the quadratic formula can be applied by substituting u = x^2. The correct zeros are derived as x = ±√(-3/32 + √137/32), which simplifies to include a factor of 1/4. This factor arises from the application of the quadratic formula, where the leading coefficient of the quartic term influences the final result. The discussion clarifies the relationship between the derived solutions and the coefficients used in the calculations.
karush
MHB
Find the zeros
$$f(x)=16x^4+3x^2-2$$
ok I presume we can solve this with the quadratic formula even with powers of 4 and 2
by setting $u=x^2$ I was able to get$$x=\pm\sqrt{-\frac{3}{2}+\frac{\sqrt{137}}{2}}$$but $W\vert A$ says the answer is$$x=\pm\frac{1}{4}\sqrt{-\frac{3}{2}+\frac{\sqrt{137}}{2}}$$where does the $\frac{1}{4}$ come from?
$$\tiny{140.56}$$
Mathematics news on Phys.org
You should get (when applying the quadratic formula and discarding the complex roots):
$$x=\pm\sqrt{-\frac{3}{32}+\frac{\sqrt{137}}{32}}$$
The 32 comes from twice the coefficient of the 4th degree term. And this is equivalent to W|A's result.
Start by dividing by 2: 8x^4 + (3/2)x^2 - 1 = 0
\begin{align}\displaystyle
y&=8x^4 + (3/2)x^2 - 1 \\
&=\frac{-(3/2)\pm\sqrt{(3/2)^2-4(8)(-1)}}{2(8)}\\
&=\frac{1}{16} \left(-\frac{3}{2} \pm \frac{\sqrt{137}}{2}\right)
\end{align}
maybe:rolleyes:
The square root of that changes the 1/16 to 1/4
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
