Fine structure constant and energy scale
In summary: This is a good question. When you increase the energy scale, you are increasing the momentum of the particles. This means that you can probe closer to the bare charge.
asimov42
377
Hi all,
I have a rather naive question about the fine structure constant and the relationship between its value and the energy scale involved.
I understand the idea of the a charge being 'screened' by vacuum polarization (i.e., electron-position pairs popping in and out of existence), and that the value of the fine structure constant is approx. 1/137 for a 'dressed' charge at an infinite distance. What I don't understand is what exactly it means to 'increase' the energy scale.
If we were to simply accelerate, say, an electron, to a high velocity (without smashing it into anything), would we expect the electromagnetic interaction with a passing proton to be stronger, since the electron has more kinetic energy? This doesn't seem right, since velocity is relative. Or does the energy scale only matter in a collision?
I guess I'm not really clear on the meaning of energy scale; when other posts refer to the energy scale as increasing at shorter distances, does this mean the value of the fine structure constant would effectively be different when measured 'near' the electron?
Sorry if this has already been dealt with - I searched through the archives but wasn't able to find an answer to these specific questions.
Certainly velocity is relative but if you are on a lab and you accelerate very much an electron, probably the protons will have a speed "similar" to the lab and therefore the relative velocity between the electron and the proton will be big. In that case, since the electron comes to the proton with a higher speed, the coulomb force needed to repel the electron will be greater and the interaction as well.
By the way, what has this to do with the fine structure constant??
tom.stoer said:
The relevant energy scale is the invariant mass M² = P² where P is the sum over the 4-momenta of all particles involved in a process; http://en.wikipedia.org/wiki/Coupling_constant
Thanks Tom - I'm still a bit foggy though... from other reading, I surmise that as the energy scale increases, greater momentum transfer is involved. Does this mean that by using a higher energy probe, one gets closer to the 'bare' charge (i.e., there's less screening by vacuum polarization, since the interactions are occurring over shorter distances)? Not sure if that makes sense.
Thanks.
Related to Fine structure constant and energy scale
1. What is the fine structure constant?
The fine structure constant, denoted by the symbol α (alpha), is a dimensionless number that characterizes the strength of the electromagnetic force. It is approximately equal to 1/137 and is a fundamental constant in quantum electrodynamics.
2. How is the fine structure constant related to energy scale?
The fine structure constant is related to the energy scale through its appearance in equations that describe the behavior of subatomic particles at high energies. It is a measure of the strength of the electromagnetic interaction between these particles and is crucial in understanding their behavior at different energy scales.
3. Why is the fine structure constant important in physics?
The fine structure constant is important in physics because it is one of the fundamental constants that govern the behavior of subatomic particles. It is used in various equations and theories, such as quantum electrodynamics, to describe the interactions between particles at different energy scales.
4. How is the fine structure constant determined?
The fine structure constant can be determined experimentally by measuring the strength of the electromagnetic interaction between charged particles. It can also be calculated theoretically using equations that describe the behavior of these particles.
5. Can the value of the fine structure constant change?
The value of the fine structure constant is believed to be a fundamental constant of the universe and is not expected to change. However, some theories suggest that it may vary slightly at extremely high energy scales, which is an area of ongoing research in theoretical physics.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Beyond the Standard Models
