Fine tuning - island of stability of our world
In summary, the conversation discusses the conditions necessary for our universe to exist, including CP violation, unstable particles, and the existence of dark matter. The question is raised if there is an attempt to create a list of all known conditions from different fields and map them to parameters of the standard model. It is mentioned that the 'island of stability' is very small and there may be other islands that allow for life to develop. The idea of multiple branes with different SM parameters and metrics is also mentioned. The possibility of an external, bulk time is discussed and it is suggested that time may be local to each brane.
Dmitry67
2,567
I know some fine-tuning conditions which must be true in order for our universe, as we know it, to exist, for stars to shine and for the life to develop.
For example,
* CP violation (otherwise no matter because everything would annihilate)
* Diproton (p+p) must be unstable (otherwise stars will burn out too quickly)
* neutron should be unstable (important in the early universe)
* dark matter exists (otherwise Jeans mass is too big in early universe - galaxies do not form)
* there should be no stable particles containing 5 and 8 hardrons (otherwise stars will burn out too quickly)
* etc, etc, etc
My question is if there are any attemptx to create - not a full list of such conditions of course, but at least put in that list all we know - from astronomy, chemistry, star evolution, biochemistry etc.
And them map these conditions to 30 parameters of the standard model + 2 parameters beyond standard model (percentages of DM and DE)
I know the 'island of stability' is very small. But what exactly is it's size?
P.S. More difficult question - are there any OTHER islands of stability which allow for life to develop (even chemistry might be completely different?)
Space news on Phys.org
go to craigslist religion forum and do a search for 'fine tuning'. you will find a pretty good list.
You don't need fine tuning to find worlds such as ours, just blind luck. Many worlds like ours surely exist in a universe as large as ours.
Wih different parameters of the SM? Sure, but in most of them there are no observers
His subject was contradictory to his main point which was:
Not that you need fine-tuning for a world such as ours, but that you need fine-tuning for a universe such as ours to exist.
As to your point, it's not blind luck, but lots of time that is the key ingredient. A lot more than 20 billion years for our brane. The universe can be for a trillion billion years; thus everything can happen. No luck required.
I was thinkig that there are many DIFFERENT branes with different worlds inside. These worlds differ in the SM paramaeters and in metrics (number of space dimensions, number of time dimensions)
You suggest that everything can happen even on the same brane? But it requires at least 2 things:
* SM parameters must change from time to time in the same Universe (?)
* Entropy must be reduced (no known mechanism)
For example, give our universe 10**100 years. It will completely burn out, leaving only elementary particles and black holes. Now you can change SM parameters, but it is TOO LATE - new stars will never form - there is nothing left.
Anthropic principle works only if new universe is created from scratch every time, with zero entropy
Right.
I am not suggesting that everything must happen on the same brane.
Sorry, I did not interpret your words correctly
But when you were saying:
Did you mean that there is an 'external' time - BULK time? I am not sure, but it is quite probable that time is local to a brane, so different brances have different times pointing to different directions. Some brances could have >1 time or no time at all.
Regarding the BULK, I don't know if there is something we can call 'time' there...
Related to Fine tuning - island of stability of our world
What is the "fine tuning" theory?
The "fine tuning" theory is the idea that the physical constants and laws of the universe are precisely balanced in order for life to exist on Earth. This theory suggests that if any of these constants were even slightly different, life as we know it would not exist.
What is the "island of stability" in relation to fine tuning?
The "island of stability" refers to the hypothetical region on the periodic table where superheavy elements with longer lifetimes are predicted to exist. This theory suggests that these elements could potentially have a significant impact on the fine tuning of our universe.
How does the concept of fine tuning relate to the origin of the universe?
The concept of fine tuning suggests that the precise balance of physical constants and laws necessary for life to exist could not have occurred by chance, leading some to believe that there must have been some sort of intelligent design or creator behind the origin of the universe.
What evidence supports the theory of fine tuning?
One piece of evidence for fine tuning is the anthropic principle, which states that the universe must be compatible with the existence of observers (humans). Additionally, the discovery of the "Goldilocks Enigma" – the fact that Earth is in the perfect location in our galaxy for life to exist – also supports the theory of fine tuning.
What are the criticisms of the fine tuning theory?
One major criticism of the fine tuning theory is the lack of empirical evidence to support it. Some argue that the apparent "fine tuning" of the universe could simply be a result of the anthropic principle and the fact that we exist in this particular universe. Additionally, the concept of fine tuning is often seen as a religious or philosophical argument rather than a scientific one.
  • Cosmology
  • Cosmology
  • Cosmology
  • Beyond the Standard Models
