Finging the charge on each capacitor in series
In a series circuit with two capacitors, C1 (55μF) and C2 (15μF), connected to a 5.5 V battery, the charges on the capacitors can be determined using the equations C=Q/V and the Loop Rule. When the switch has been closed for a long time, the capacitors reach their maximum charge, and no current flows through the circuit. The total charge (Qtotal) is equal to the charge on each capacitor, as they share the same charge in a series configuration. The relationship between the charges can be explored further by calculating the equivalent capacitance and voltage drops across each capacitor. Understanding these principles is essential for solving the problem effectively.
CogitoEAS
Finding the charge on each capacitor in series
In the circuit in the figure below, assume the resistance values are R1=1,400Ω and R2=2,500Ω, C1=55μF and C2=15μF, and the emf=5.5 V. The switch is labeled S.
Consider the circuit in the figure below and assume the switch has been closed for a very long time.
What are the charges on the two capacitors?
C=Q/V, Loop Rule - 5.5-(Q1/55e-6)-(Q2/15e-6)=0, 1/Ceq=(1/C1)+(1/C2)
I think I'm just blanking on something here because it's either a matter of finding the potential across each capacitor or finding another equation relating Q1 and Q2 so that I can solve for both. Maybe Qtotal=CV(1-e^(-t/tau))=Q1+Q2?
What is the question?
How are the charges on series capacitors related?
ehild
Likes 1 person
Yes, sorry, I've added the central question "What are the charges on the two capacitors?" to the original post. I'm also 100% sure I spelled FINDING right in the title but for some reason the d keeps getting changed to a g?!
Thank you!
And we hen they say it has been switched on for a very long time they are hoping you will reason out 'the capacitors are as charged as they ever will be, so no current isnflowingr, now the voltage drop across resistors when there is no current is...'
  • · Replies 19 ·
9K
