Finite product of complex terms
In summary, the conversation discusses a problem in finding a general formula for P(n), which is the product of a series involving square roots and imaginary numbers. The problem arises from a geometrical problem involving a spiral that interpolates a sequence of vertices in orthogonal triangles. The solution involves evaluating angles and using a continuous function, but the problem cannot be solved through a simple closed form solution and requires a table of sampled values.
Gazouille
Can one hint me towards finding a general formula for
[tex]
P_n = \prod_{x=0}^{n} \left( \sqrt{x} + i\right)
[/tex]
I need a direction because now I'm stuck with it after having struggled to formulate it.
Either the real or imaginary part would be enough but i guess i won't get one without the other. I'm working out now the term to renorm the result, i'll post it asap, it's nothing complicated.
This current formulation I made up for a geometrical problem i have :).
It is to evaluate exactly a spiral that interpolates a sequence of vertices in orthogonal triangles that you would stitch together (by hypothenuse to the variable length side of the next). I can make a drawing if necessary.
I need to sum up angles for each triangle to get a polar coordinate of the n-th vertex. Hopefully evaluable through a simple continuous function to get the in-betweens aswell.
I started with trying to work in log space but what i naturally get is a sum of arc-cosinuses that i can't find an interpolating function for...
Thanks for any hint :)
I guess you should use letters of the smaller case, i.e. [tex], and not [TEX], for the LATEX to be displayed.
yes i thought so, i changed it, crossing fingers :)
in case it doesn't like me, it's : P(n) equals product for x=0 to n of (sqrt(x)+i)
Well, by now I still haven't solved this problem but I found it's called the Spiral of Theodorus and there is no simple closed form solution althought the problem looks so simple :).
In addition, the solutions are converging series that, well... converge very very slowly.
So, I'm going to use a table of sampled values for my function and that's going to be all.
FAQ: Finite product of complex terms
What is a finite product of complex terms?
A finite product of complex terms refers to a mathematical expression that involves multiplying a fixed number of complex numbers, variables, or functions together. It is a common mathematical operation used in various fields of science, such as physics, engineering, and economics.
How is a finite product of complex terms calculated?
To calculate a finite product of complex terms, you multiply each term together using the standard rules of complex number multiplication. This involves multiplying the real parts, multiplying the imaginary parts, and then combining them to get the final result.
What are some applications of finite product of complex terms?
Finite product of complex terms is commonly used in signal processing, control systems, and circuit analysis. It is also used in solving problems involving probability, statistics, and optimization.
How does a finite product of complex terms differ from a finite sum of complex terms?
A finite product of complex terms involves multiplication, while a finite sum of complex terms involves addition. Additionally, a finite product can result in a complex number, while a finite sum always results in a real number.
Are there any special properties of finite product of complex terms?
Yes, a finite product of complex terms has several special properties, including the commutative, associative, and distributive properties. These properties can be used to simplify complex expressions and make calculations easier.
