Finitely Generated Modules and Their Submodules ....
  • I
  • Thread starter Math Amateur
  • Tags
    Modules
L = L+0 \subseteq M+L##So for ##m=0## we have ##M=x_0R+L## and we are done, because ##x_0R+L## is the shortest presentation we could get (##m=0##).
Math Amateur
MHB
3,998
48
I am reading An Introduction to Rings and Modules With K-Theory in View by A.J. Berrick and M.E. Keating (B&K).
I need help with the proof of Lemma 1.2.21 ...
Lemma 1.2.21 and its proof reads as follows:
Question 1In the above text by Berrick and Keating, we read the following:"... ... Since ##M## is finitely generated, there is a minimal subset ##\{ x_0, \ ... \ ... \ , x_s \}## of ##M## such that
##x_0 R + \ ... \ ... \ , x_s R + L = M. \ ... \ ... \ ...## "My problem is as follows:
I cannot see exactly why there exists a minimal subset ##\{ x_0, \ ... \ ... \ , x_s \}## of ##M## such that
##x_0 R + \ ... \ ... \ , x_s R + L = M##. ... ... ...Can someone please demonstrate, rigorously and formally, that there exists a minimal subset ##\{ x_0, \ ... \ ... \ , x_s \}## of ##M## such that
##x_0 R + \ ... \ ... \ , x_s R + L = M##?
Question 2In the above text by Berrick and Keating, we read the following:"... ... Let ##S## be the set of submodules ##X## of M that contain ##x_1 R + \ ... \ ... \ , x_s R + L## but do not contain ##x_0##. It is obvious that ##S## is inductive ... ...Can someone please explain exactly why ##S## is inductive ... ... ?Hope someone can help ...
Peter========================================================================B&K's definition of "inductive" is contained in section 1.2.18 ... ... . which reads as follows:
To your first question.
##M## is finitely generated, so it can be written ##x_0R+\dots +x_mR=M##. Furthermore ##L \subseteq M##, so ##M=x_0R +\dots +x_mR +L##. (I simply added it, not bothering about minimality or so.) This means ##M## can be written in such a way. Now chose among all possible ways to do this a shortest ## \{x_0, \dots , x_s\}##, that is with the smallest ##s## needed. It doesn't have to be unique, only with the fewest elements such that ##M=x_0R +\dots +x_sR +L##.
##m## would do, but it might not be the smallest number. However, we only have numbers ##1## to ##m##. Somewhere has to be the smallest which we call ##s##.
To the second part.
We have submodules that contain ##\{x_1 , \dots , x_s\}## and ##L##. ##S## is the set of these submodules. ##S## is partially ordered by inclusion. Either ##X \subseteq Y## or ##X \nsubseteq Y## for any two ##X,Y \in S##.
Therefore we can build chains ##X_0 \subseteq X_1 \subseteq \dots \subseteq X_n## in ##S##. The condition to belong to ##S## is to contain ##x_1, \dots , x_s## and ##L## and not ##x_0##. This is true for all ##X_i## and it is also true for ##\cup_i X_i##. Therefore ##\cup_i X_i \in S##, which is the condition to be inductive. Because we only deal with indices ##1, \dots ,s## we can take ##\Lambda =\{1, \dots ,s\}## as ordered index set.
Likes Math Amateur
To the second part.
Thanks for the reply, fresh_42 ... ... but i do not follow you when you write:
"... ... ##M## is finitely generated, so it can be written ##x_0R+\dots +x_mR=M##. Furthermore ##L \subseteq M##, so ##M=x_0R +\dots +x_mR +L##. ... ...Why is this true ... ?
Specifically, how, exactly, do we get from ##L \subseteq M## to the conclusion that ##M=x_0R +\dots +x_mR +L## ... how do we justify this ...
Peter
Peter
What does it mean that ##M## is finitely generated?
##M## is finitely generated if we have ##M = x_0 R + x_1 R + \ ... \ ... \ + x_m R## for some finite set ##X = \{ x_0, x_1, \ ... \ ... \, x_m \}##
Peter
Peter
Yes, so ##M = x_0 R + x_1 R + \ ... \ ... \ + x_m R## and ##L## is a submodule of ##M##.
So ##L \subseteq M = x_0 R + x_1 R + \ ... \ ... \ + x_m R## and ##M=M+L= x_0 R + x_1 R + \ ... \ ... \ + x_m R+L##.
The crucial point here is ##M=M+L##, which is true because
a) ##M \subseteq M+L##
b) ##L \subseteq M \, \wedge \, M \subseteq M \, \Rightarrow \, M+L \subseteq M## since ##M## is closed under addition. You can't escape ##M## by addition.
Edit: A simple example is ## R=\mathbb{Z}\, , \,M=6\mathbb{Z}\, , \,L=36\mathbb{Z}##. What is a maximal submodule of ##M=6\mathbb{Z}## that isn't ##M## itself and contains ##L=36\mathbb{Z}##? And is there only one maximal submodule?
Likes Math Amateur
Thanks again, fresh_42 ... ...
You write: "" ... ... The crucial point here is ##M=M+L## ... ...
Indeed that is crucial ... ... would not have guessed that ...
Now, catching on to your thoughts ... but just a quick question ...
You write:
"... ... ##L \subseteq M \, \wedge \, M \subseteq M## ... ...
what do you mean by ## M \, \wedge \, M## ... ?
Peter
Math Amateur said:
"... ... ##L \subseteq M \, \wedge \, M \subseteq M ... ...##
what do you mean by ##M \, \wedge \, M## ... ?
No, the ## \wedge ## isn't prior to ##\subseteq##.
It is a logical symbol and stands for ##\text{ and } ##.
So it reads ##(L \subseteq M) \, \text{ and } \, (M \subseteq M) \, \Longrightarrow \, (L+M) \subseteq M##.
(For the record: ## \vee## stands for the logical ##\text{ or }##. The similarity to ##\cap## and ##\cup## isn't accidental.)
Likes Math Amateur
Thanks for your help fresh_42 ... I doubt I would have understood this issue without your help ...
Most grateful ...
Peter
Most grateful ...
Peter
You're welcome, Peter!
But have a thought or two on my example:
##R=\mathbb{Z}\, , \,M=6\mathbb{Z}\, , \,L=36\mathbb{Z}##.
What is a maximal submodule of ##M=6\mathbb{Z}## that (isn't ##M## itself and) contains ##L=36\mathbb{Z}##?
Hi fresh_42 ...
I have to confess that I have no idea how to, formally and rigorously determine the maximal submodule of ##6 \mathbb{Z}## ... but intuitively it seems that the maximal submodule would be ##N = 12 \mathbb{Z}## ... is that correct ...?
How would you go about formally and rigorously determining the maximal submodule of ##6 \mathbb{Z}## ... ?
Peter
Math Amateur said:
Hi fresh_42 ...
Peter
It is about the maximal submodules, that contain ##L##.
Since each element of ##M=6\mathbb{Z}## is a multiple of six, submodules can also only contain multiples of six. Starting with six, we get ##M##. So other multiples, like ##N=12\mathbb{Z}## are proper submodules. And ##N## contains ##L=36\mathbb{Z}##, that is also correct, since multiples of ##36## are also multiples of ##12##. But there is another proper submodule, ##N'##, which also contains ##L##. And it is maximal, too. It should show you, that maximal submodules of ##M## which contain ##L## don't need to be unique.
Maximality (of ## N##) in general is shown by the pattern ##N \subseteq P \subseteq M \, \Longrightarrow \, P=N \text{ or } P=M## that is nothing fits between a maximal element and the entire module. In the case of integers it is quite simple because one must only deal with multiples and divisors and all can be generated by only one element.
Likes Math Amateur
Thanks for the helpful example fresh_42 ...
I suspect that the other maximal submodule of ##M## containing ##L## is ##18 \mathbb{Z}## ... is that correct?
Peter
Likes fresh_42
Peter
You get for each prime number ##p## a maximal submodule ##6p\mathbb{Z} \subseteq 6\mathbb{Z}##. Of course only ##p\in\{2,3\}## contain ##L=36\mathbb{Z}## because all other primes don't contribute to the second ##6## which is needed for ##36##.
Likes Math Amateur
Related to Finitely Generated Modules and Their Submodules ....
What is a finitely generated module?
A finitely generated module is a mathematical structure that arises in abstract algebra and linear algebra. It is a generalization of the concept of a vector space, where instead of working with a field of scalars, we work with a ring of scalars.
What is the significance of finitely generated modules?
Finitely generated modules are important because they allow us to study structures that are not necessarily finite-dimensional, but still have a finite basis. This allows for a better understanding of abstract algebraic structures such as rings and fields.
What are submodules?
Submodules are subsets of a module that also satisfy the axioms of a module. They are analogous to subspaces in linear algebra, where the operations of addition and scalar multiplication are defined over a field. In the context of finitely generated modules, submodules are important because they help us understand the structure of the module as a whole.
How do you determine if a submodule is finitely generated?
A submodule is finitely generated if it can be generated by a finite set of elements. This means that every element in the submodule can be expressed as a linear combination of these generators. To determine if a submodule is finitely generated, we can check if it is spanned by a finite set of elements.
What is the relationship between finitely generated modules and vector spaces?
Finitely generated modules are a generalization of vector spaces, where the scalars are replaced by elements of a ring. This means that many of the properties and theorems that hold for vector spaces also hold for finitely generated modules, but with some modifications to account for the different algebraic structure.
  • Linear and Abstract Algebra
