First derivative of the legendre polynomials
In summary, the first derivative of the Legendre polynomials satisfies a self-adjoint differential equation with eigenvalue λ=n(n+1)-2. By substituting the first derivative with "y" and differentiating, the equation becomes (1-x^2)y''-4xy'=(2+λ)y.
kilojoules
show that the first derivative of the legendre polynomials satisfy a self-adjoint differential equation with eigenvalue λ=n(n+1)-2
The attempt at a solution:
(1-x^2 ) P_n^''-2xP_n^'=λP_n
λ = n(n + 1) - 2 and (1-x^2 ) P_n^''-2xP_n^'=nP_(n-1)^'-nP_n-nxP_n^'
∴nP_(n-1)^'-nP_n-nxP_n^'=( n(n + 1) - 2 )P_n
For n=2
2P_1^'-2P_2-2xP_2^'=4P_n
Using legendre polynomial properties we have
-9x^2+2x+1=2(3x^2-1)
∴-15x^2+2x+3=0
I don’t know what to do from here.
Did you consider just replacing the first derivative with just "y" so that the equation becomes
[tex](1- x^2)y'- 2xy= \lambda P_n[/tex]
Differentiating
[tex](1- x^2)y''- 4xy'- 2y= \lambda P_n'= \lambda y[/tex]
[tex](1- x^2)y''- 4xy'= (2+ \lambda)y[/tex]
Thanks Hallsofvy
FAQ: First derivative of the legendre polynomials
What is the first derivative of the Legendre polynomials?
The first derivative of the Legendre polynomials is a mathematical operation that calculates the rate of change of the polynomials with respect to their independent variable. In simpler terms, it measures how the polynomial changes as its input variable changes.
Why is the first derivative of the Legendre polynomials important?
The first derivative of the Legendre polynomials is important because it allows us to analyze the behavior and characteristics of the polynomials. It helps us understand the slope and curvature of the polynomials, which are crucial in many mathematical applications.
How is the first derivative of the Legendre polynomials calculated?
The first derivative of the Legendre polynomials can be calculated using the differential equation P'(x) = n*(Pn-1(x) - x*Pn(x))/(1-x2) where n is the order of the polynomial and Pn(x) is the Legendre polynomial of order n.
What is the relationship between the first derivative of the Legendre polynomials and the Legendre function?
The first derivative of the Legendre polynomials is closely related to the Legendre function, which is a generalization of the polynomials. The Legendre function can be expressed as a sum of the Legendre polynomials multiplied by their corresponding coefficients, and the first derivative of the Legendre polynomials can be used to find these coefficients.
What are the applications of the first derivative of the Legendre polynomials?
The first derivative of the Legendre polynomials has various applications in mathematics, physics, and engineering. It is commonly used in solving differential equations, analyzing the behavior of physical systems, and approximating other functions. It also has applications in numerical analysis, signal processing, and image processing.
