First Experimental Confirmation of GR
In summary, according to relativity, the bending of light around the sun is due to the curvature of spacetime around the mass.
phoenix-anna
TL;DR Summary
Looking for an explanation of the curved path of light as it passes the sum
Trying to understand how Einstein predicted the appearance of stars during the solar eclipse around the turn of the 20th century (the first experimental confirmation of General Relativity, I believe). My impression, which is not physically correct, is that the sun attracts the photons as they pass by, causing their trajectory to bend. Actually, in GR there is no such thing as gravitational force, right? It is a matter of curvature. I understand that particles with mass follow geodesics, paths where the length (using the relativistic metric, I assume) is minimal. HOwever, I don't believe that GR treats photons as particles having mass but rather treats light as electromagnetic radiation. So that brings me to my question: what is relativity's explanation for the shift in the apparent position of these stars? What is the status of electromagnetic radiation in GR?
My confusion is amplified by my impression that in relativity, light always travels a light-like path where the length is zero: s^2=c^2 t^2-x^2=0
Likes vanhees71, Dale and sysprog
Photons only appear when we do a full quantum mechanical treatment of electromagnetic radiation, so are basically irrelevant to discussions of relativity; instead we treat light as classical electromagnetic radiation covered by Maxwell’s laws.
Light travels in a straight line, but in a curved spacetime the straight line paths don’t behave the way they do in Euclidean space: initially parallel lines may converge or diverge and end up heading in different directions. That’s why light appears to be deflected as it passes through the curved spacetime near a massive body.
That is true only in flat spacetime. In curved spacetime the length (better called the “interval” because it’s not the length of anything) of a lightlike path is still zero, but the equation describing it is appreciably more complicated and ends up describing a curved path (the solution to your equation with ##s^2=0## is the straight line path ##x=ct##). To find the appropriate equation for the path of light in a curved spacetime we have to solve the “geodesic equation”; Einstein did that for the spacetime around the sun to calculate the expected path of light around the sun.
As @Nugatory said, GR is a classical theory so we treat light using Maxwell's Equations, adapted for use in curved spacetime.
For the case of light bending by the Sun, we can further simplify things by using what is called the geometric optics approximation, where we treat light as rays following null geodesic worldlines in curved spacetime. That approximation is what @Nugatory was describing in his post.
phoenix-anna said:
Summary:: Looking for an explanation of the curved path of light as it passes the sum
That is correct. Light also travels on geodesics, but they are not the same geodesics in which massive objects travel. They are null geodesics. The concept is similar, but with some slight differences. A null geodesic extremizes the path length, but actual interval will always be zero. Also, since proper time is undefined on a null path you need to use an affine parameter instead. Those two issues are more or less just technical mathematical subtleties, and conceptually it is the same general idea as for massive particles.
Likes vanhees71 and sysprog
In addition to what others have said, from a given point in spacetime (event), in either SR or GR, there are geodesics (locally straight paths) going in all directions that can be parameterized by 3 parameters (two spatial angles, and a hyperbolic angle called rapidity, which represents an "angle in the timelike direction"). Two light cones are defined by any choice of spatial angles, and a particular rapidity that produces null interval along the path - the path followed by light pulses. These null geodesics define light cones. The interior of these contain the timelike geodesics, the exterior contain the spacelike geodesics.
Likes vanhees71 and Dale
Actually, the "rapidity" corresponding to a null interval would be infinite, yes?
This is a good description:
https://www.mathpages.com/rr/s8-09/8-09.htm
Right, and for spacelike directions, the rapidity becomes a complex number. I should have used a different third parameter, perhaps simply ##\beta##, so lightlike =1, timelike < 1, spacelike > 1, to avoid such complications.
You can just use an arbitrary parameter to describe a null geodesic. Most convenient are affine parameters of course. You just extremize the action
$$S[q]=\int \mathrm{d} \lambda \frac{1}{2} g_{\mu \nu} \dot{q}^{\mu} \dot{q}^{\nu}.$$
This "square form" has the great advantage that you can use it also in the limit of "massless particles" (though photons are not massless particles as already stressed above). The fact that the Lagrangian doesn't explicitly depend on ##\lambda## implies that the "Hamiltonian"
$$H=\dot{q}^{\mu} \frac{\partial L}{\partial \dot{q}^{\mu}}-L=L=\text{const}$$
along the solutions of the equations of motion.
For "massless particles" ##L=0##, i.e., you solve the equations of motion with ##L=0## to get the null geodesics of the spacetime. Then ##\lambda## has no specific physical meaning. It's just an arbitrary parameter parametrizing the null geodesics.
For massive particles you have ##L>0## (west-coast convention) and you can choose ##\lambda=\tau##, the particle's proper time along it's path by setting ##L=c^2/2##.
Related to First Experimental Confirmation of GR
1. What is the "First Experimental Confirmation of GR"?
The "First Experimental Confirmation of GR" refers to the first successful test of Albert Einstein's theory of General Relativity (GR) through scientific experimentation. This occurred in 1919 during a total solar eclipse, where the bending of light around the Sun was observed and confirmed the predictions of GR.
2. How was the "First Experimental Confirmation of GR" conducted?
The experiment was conducted by a team of astronomers led by Sir Arthur Eddington. They traveled to the island of Principe off the coast of Africa and the city of Sobral in Brazil to observe the total solar eclipse. During the eclipse, they measured the positions of stars near the Sun and compared them to their positions when the Sun was not in the way. The observed deflection of starlight matched the predictions of GR, providing evidence for the theory.
3. Why was the "First Experimental Confirmation of GR" significant?
The "First Experimental Confirmation of GR" was significant because it provided strong evidence for Einstein's theory of General Relativity, which revolutionized our understanding of gravity and the universe. It also validated the concept of space-time curvature, which is a fundamental aspect of GR and has been confirmed by numerous subsequent experiments.
4. What impact did the "First Experimental Confirmation of GR" have on science?
The "First Experimental Confirmation of GR" had a significant impact on science by solidifying Einstein's theory of General Relativity as a fundamental pillar of modern physics. It also opened the door for further research and experimentation into the nature of gravity and the universe, leading to many groundbreaking discoveries and advancements in our understanding of the cosmos.
5. Has the "First Experimental Confirmation of GR" been replicated?
Yes, the "First Experimental Confirmation of GR" has been replicated numerous times since 1919, using more advanced technology and methods. These replications have consistently confirmed the predictions of GR and have further strengthened our confidence in the theory. The most recent replication occurred in 2019 during the 100th anniversary of the original experiment, using modern equipment and techniques to achieve even more precise results.
