First law of Kepler explained without mass ?
In summary, the conversation discussed the possibility of explaining Kepler's first law without any use of mass. While Kepler himself arrived at his laws through empirical observation, later scientific theories such as Newton's Law of Gravitation and Einstein's General Relativity require the concept of mass to explain the laws. The possibility of using kinematics and geometry to explain the laws without mass was also brought up, with a link to a paper providing an alternative explanation. However, the concept of mass still plays a crucial role in most explanations of Kepler's laws.
hcl
Hello,
I have a question : is it possible to explain the first law of Kepler without any concept of mass ?
Kepler's first law states that satellites are moving on an ellipse and the object around which they are orbiting is localized at the focus of this ellipse. As far as I know Newton and Einstein explained this special natural behavior, in two different ways, and they needed to introduce the concept of mass to achieve this goal. However Galileo from the top of the Pisa tower, and the astronauts from the moon, experienced that bodies are falling at the same speed what ever their masses are. Therefore would it be possible to explain Kepler's first law without any use of the mass ?
Thanks for contributions.
Best regards
Herve
Science news on Phys.org
If I recall my intro. to spacecraft performance//orbital mechanics, Kepler himself was essentially a strictly observational scientist, and derived his laws from hard astronomical observation (independent of the masses of the bodies in orbit).
Ummm...you are correct that when Kepler originally arrived at his laws, they were empirical laws, meaning that the only justification for thinking that they should be so was because they were observed to be so.
However, the OP asked if it was possible to explain Kepler's laws (something which Kepler himself made no attempt to do because he did not have the tools and making mathematical models to explain nature was not really a discipline that was very well developed until Newton came along.) Furthermore, the OP asked whether this could be done without reference to the concept of mass. My answer would be that the theoretical foundation for Kepler's laws lies with Newtonian Mechanics and the equations of motion that follow from it. More specifically, all three of Kepler's laws can be explained if you know Newton's Law of Gravitation (whose formulation definitely includes a physical quantity known as "mass"). Therefore, I think the answer to the OP's question is, "no."
Even General Relativity, which abandons the notion of "gravitational force" and explains the curved paths of the planets as their most natural paths in a curved space-time, still talks about the quantity that causes that curvature, namely mass.
You mentioned that Galileo showed that the accelration of projectiles due to gravity is mass independent, but this is really only from an observational view and only when the masses involved negligibly attract the astronomical body in question (like the earth).
You're thinking in terms of relative acceleration. The universality of free fall is true even when the masses involved significantly attract the astronomical body. A golf ball in Earth free fall will accelerate the same as the moon in Earth free fall. If it were not true then the golf ball would require less velocity to maintain the same orbit as the moon.
Yes indeed Kepler produced the 3 laws as a result of observations but we had to wait for Newton, and then for Einstein, to give a theoretical interpretation of these observations. As I thought and as Cepheid explained Newton's gravitation and Einstein's general relativity need both to introduce the concept of mass to explain the laws.
Well, I think however that it is possible to give an explanation of Kepler's laws with the only help of kinematics and geometry but without the use of the mass. I wrote a short paper to explain it :http://www.oceanvirtuel.com/physics/geometrie_des_lois_de_kepler_en.pdf . I would much appreciate if you could give me your opinion about it.
Best regards
Herve
I think the crux of this matter lies within what is meant by 'explain.' Is there any kinematics that does not use the concept of mass? Kepler's Laws, if you look at the words at face value, are obviously kinematic(A planet moves...) but I do not know of a way one can understand kinematics without the use of mass.
As I said the best would be to read this short paper : http://www.oceanvirtuel.com/physics/geometrie_des_lois_de_kepler_en.pdf
It explains more clearly how to get Kepler's laws without using the mass. Any opinion about it would be appreciated.
FAQ: First law of Kepler explained without mass ?
What is the first law of Kepler?
The first law of Kepler, also known as the law of ellipses, states that all planets in our solar system move in elliptical orbits with the sun at one of the focal points of the ellipse.
How is the first law of Kepler related to mass?
The first law of Kepler does not depend on the mass of the planet or the sun. It describes the shape of the orbit and the position of the sun, but not the masses of the bodies involved.
What does the first law of Kepler explain?
The first law of Kepler explains the shape of planetary orbits in our solar system. It also applies to other objects that orbit a central body, such as moons orbiting planets or artificial satellites orbiting Earth.
Why is the first law of Kepler important?
The first law of Kepler is important because it helped to revolutionize our understanding of the solar system and the universe. It was a key piece of evidence for the heliocentric model of the solar system, which states that the sun is at the center and the planets orbit around it.
Can the first law of Kepler be applied to all planetary systems?
Yes, the first law of Kepler applies to all planetary systems. It is a fundamental law of physics that describes the motion of objects in orbit around a central body, regardless of the specific masses or sizes of the objects involved.
