First Law of Thermodynamics - Correct Formulation?
In summary, the conversation is about a problem in thermal physics involving a gas expanding and the different formulations of the first law of thermodynamics. The first formulation states that the change in internal energy is equal to the sum of the energies transferred to the system, while the second formulation states that heat flow is equal to the change in internal energy plus work. The confusion lies in the sign of work, but it is clarified that textbooks now use the second formulation. The problem is solved using the second formulation and the assumption that work done by the gas is positive. It is also mentioned that the gas expands in such a way that pressure is directly proportional to
guyguy
A gas expands from 1L at 1atm to 3L. Assume P is directly proportional to V.
This is a simple question from my second lecture on Thermal Physics, and I have found a way to solve it after my professor made it very confusing in class. My question is more about the formulation of the first law of thermodynamics than this problem in particular. I am confused as to what formulation is valid under what assumptions, rather what assumptions make Eq. 1 (below) valid?
My professor in class stated the first law of thermodynamics as such:
[tex]\Delta E = q + w[/tex] Eq. (1)
Whereas in Baierlein, our course book, it is stated as:
[tex]q = \Delta E + w [/tex] Eq. (2)
I have a reference book (Theoretical Physics by George Joos, Dover Edition) that addresses this discrepancy. They present Eq. (1) as one form of the First Law of Thermodynamics under the conditions that all forms of energy are considered to be positive. My thought in this case is that the change in internal energy would not be negative even when the gas expands, and it is up to whomever is using the equation to determine the sign using physical intuition.
Secondly, when they discuss "a change in volume accompanying an external pressure p" they derive Eq. (2) as a special case of the first law, wherein the quantities of the different forms of energy can be either positive or negative. This seems much more intuitive to me.
I believe I was able to solve the problem using the second equation and taking the work done by a gas on its surrounding to be positive (and compression to be negative work), but I cannot see how to solve the problem--or even how exactly to define the problem--if the first formulation of the law is also correct. I have attached a pdf of my solution and the reference book I used. It would be helpful if someone could solve the problem using Eq. (1) and the proper assumptions.
  • gas_expansion.pdf
In 1., W is the work done ON the gas. In 2., W is the work done BY the gas. Text books used to use 1. but now most use 2. Just a different way of stating the law.
In 1. the change in internal energy of the system is the sum of the energies (heat flow and work) transferred to the system. That makes sense. But the problem was with the sign of W that always led to confusion. Work done ON the gas is [itex]-P\Delta V[/itex]
In your problem, why do you think that P changes? Does this expansion not occur at constant P = 1 atm?
AM
Okay, so that's the only difference thanks a bunch. I think my professor had mentioned that she was using a difference book for her notes than we had read. She hadn't been able to reconcile the difference by the end of class though--it just became a big mess.
Regarding why P changes, I think the confusion comes only from a poor statement of the problem. I know that in general for an ideal gas there is an inverse relationship between P and V, but the example was supposed to be more primitive than that and was just supposed to illustrate that the work was the area under the curve [tex] P(V) [/tex]. We are supposed to assume that the gas expands in such a way that the pressure remains directly proportional to the volume. Is this not possible, or can it be achieved in practice by varying other parameters?
Ok. I see that is given in the problem that [itex]P\propto V[/itex].
PV=nRT is still the relationship between P, V, and T in an ideal gas.
If the pressure is proportional to V in this process (ie. heat flows into the gas as it expands), then P/V = constant or P = kV. Use the relationship between P, V and T to determine k.
To calculate the work, you must use:
[tex]W = \int_{V_i}^{V_f} PdV = \int_{V_i}^{V_f} kVdV[/tex]
AM
So, if we use the ideal gas law, and divide by [tex]V^2[/tex]...
[tex] \frac{P}{V} = \frac{Nk_BT}{V^2} = k [/tex]
So we see that, if [tex]P \propto V [/tex], the expansion cannot be isothermal; moreover there must be a specific relationship between T and V? I don't really think that makes much sense that the proportionality constant between P and V includes V itself--it seems like that makes [tex]P \propto V^{-1}[/tex]--but I don't see a way around that. How can an ideal gas have [tex]P \propto V[/tex] then; am I just wrong in doubting that V can be included in the constant [tex]k[/tex]?
If temperature does not change [itex]P \propto 1/V[/itex]
But if T increases as the square of volume: [itex]T \propto V^2[/itex] then, since P is proportional to T but inversely proportional to V, (P=nRT/V), P will be proportional to V.
Now since P/V = k it is just a matter of finding the value of that constant. All you need is one value of P, V and T that fit the relationship (since the constant is the same for all values). We know that the initial values fit that relationship, so:
[tex]P_0 = kV_0 = nRT_0/V_0[/tex]
so:
[tex]k = nRT_0/V_0^2 = P/V[/tex]
For the relationship [itex]k = P/V[/itex] to hold,
[tex]T = PV/nR = kV^2/nR = (nRT_0/V_0^2)V^2/nR = V^2(T_0/V_0^2)[/tex]
AM
Okay, gotcha! Thanks a bunch
FAQ: First Law of Thermodynamics - Correct Formulation?
1. What is the First Law of Thermodynamics?
The First Law of Thermodynamics states that energy cannot be created or destroyed, but it can be transferred or converted from one form to another.
2. What is the correct formulation of the First Law of Thermodynamics?
The correct formulation of the First Law of Thermodynamics is: The total energy of an isolated system remains constant. This means that the energy within a closed system will always be conserved.
3. How is the First Law of Thermodynamics related to the conservation of energy?
The First Law of Thermodynamics is directly related to the conservation of energy, as it states that energy cannot be created or destroyed. This means that the total amount of energy within a system will always remain constant.
4. Can the First Law of Thermodynamics be violated?
No, the First Law of Thermodynamics is a fundamental principle of physics and has been proven to hold true in all observed systems. It cannot be violated or broken.
5. What are some real-world applications of the First Law of Thermodynamics?
The First Law of Thermodynamics has many practical applications, including understanding and predicting the behavior of engines, refrigerators, and other heat-based systems. It also helps in the study of energy conservation and sustainability in various industries and environments.
