First order term in the taylor expansion of ln(x) abut 1
In summary, the question is asking for the first order term in the expansion of ln(x) about x = 1, with the choices being x, 2x, or (1/2)x. However, the correct answer is x - 1, which is not one of the options given. This may be due to a mistake in the problem statement, as the linear term in ln(1+x) about x=0 would be x.
Mr Davis 97
1,462
44
What's the first order term in the expansion ln(x) about x = 1?
Taylor series formula
The question is multiple choice, and the choices are x, 2x, or (1/2)x. However, when I calculate the first order term in the expansion of ln(x) about 1, I get ln(1) + (1/1)(x - 1) = x - 1, which is not one of the options. What am I doing wrong?
So, what's the first order term in x - 1 ?
x... But how is that the answer if x - 1 is the first order term in the Taylor approximation?
Nothing. The problem statement is wrong or, at best, misleading. My guess is the intent was to ask what the linear term of ln(1+x) about x=0 is.
Likes SammyS
FAQ: First order term in the taylor expansion of ln(x) abut 1
1. What is the first order term in the Taylor expansion of ln(x) about 1?
The first order term in the Taylor expansion of ln(x) about 1 is simply the first derivative of ln(x) evaluated at x=1. This is represented as ln(1) = 0.
2. How is the first order term in the Taylor expansion of ln(x) about 1 derived?
The first order term in the Taylor expansion of ln(x) about 1 is derived using the Taylor series formula, which states that for a function f(x) with continuous derivatives up to the nth order, the nth order Taylor polynomial about x=a is given by: Pn(x) = f(a) + f'(a)(x-a) + (f''(a)/2!)(x-a)^2 + ... + (f^n(a)/n!)(x-a)^n. In this case, the first derivative of ln(x) is used to find the first order term at x=1.
3. What is the significance of the first order term in the Taylor expansion of ln(x) about 1?
The first order term in the Taylor expansion of ln(x) about 1 represents the linear approximation of the function ln(x) near x=1. It gives us an estimate of the function's value at x=1 and can be used to approximate the function's value at nearby points as well.
4. Can the first order term in the Taylor expansion of ln(x) about 1 be used to approximate ln(x) at values other than 1?
Yes, the first order term in the Taylor expansion of ln(x) about 1 can be used to approximate ln(x) at values near 1. However, the accuracy of the approximation decreases as the distance from x=1 increases. This is because the Taylor series is a local approximation and becomes more accurate closer to the point of expansion.
5. How does the first order term in the Taylor expansion of ln(x) about 1 relate to the derivative of ln(x)?
The first order term in the Taylor expansion of ln(x) about 1 is equivalent to the first derivative of ln(x) evaluated at x=1. This shows that the first derivative of a function can be thought of as the linear approximation of the function near a given point, in this case, x=1.
