First term test 8 mark triple TIPS question
In summary, the conversation discusses finding the values of constants a and b that satisfy a given limit equation. One of the participants suggests using the concept of a hole in the graph to determine the value of b, while the other participant mentions using calculus to solve for the values but is not sure where to begin. The conversation also touches on the importance of calculus in solving such limits.
mrjoe2
39
(note: this is not an easy question and will be marked very strictly.)
Find the values of the constant a and b such that limx->0 ((ax+b)^1/3)-2)/x = 5/12
NOTE: you are not allowed to use L'Hospital's Rules for this question
whatever you learned in calculus. there's not really specified equations to these questions
finding b is quite simple. i know that 0/0 provides a hole in the graph of this function, so i want a b value that will give me such a hole because it will be the cause of the limit approaching that hole. that's my logic however skewed it may be, but i find it to be extraordinarily beneficial. so b would simplybe 8 since 8^1/3 is 2, and 2-2 is 0 and thus you get zero over 0. finding a is another story, i need some tips because i have no idea where to begin! thank you once again for saving my life lol..
This is again a difference quotient for the derivative of the function f(x)=(ax+8)^(1/3) evaluated at x=0. To prove it from first principles you have to go back and figure out how you proved (x^(1/3))'=(1/3)*x^(-2/3). Are you making up these silly rules that you can't use calculus to solve these limits? Because the whole point to calculus is to solve limits like this without having to go back and prove them from first principles every time.
FAQ: First term test 8 mark triple TIPS question
What is a "First term test 8 mark triple TIPS question"?
A "First term test 8 mark triple TIPS question" is a type of test question that is commonly used in academic settings, particularly in science courses. It requires the student to answer a question by providing three separate answers or solutions, each worth 8 marks. The acronym TIPS stands for "Topic, Introduction, Problem, Solution," which is a helpful framework for organizing the answer.
How should I approach a "First term test 8 mark triple TIPS question"?
To effectively answer a "First term test 8 mark triple TIPS question," it is important to first carefully read the question and identify the key topic or problem. Then, use the TIPS framework to structure your answer, providing a clear introduction, outlining the problem and its significance, and offering well-supported solutions. It may also be helpful to use diagrams or examples to support your points.
What is the purpose of a "First term test 8 mark triple TIPS question"?
The purpose of a "First term test 8 mark triple TIPS question" is to assess a student's understanding and application of key concepts in a specific topic. It also tests their ability to think critically and organize their thoughts in a clear and concise manner. These types of questions are often used to evaluate a student's overall knowledge and problem-solving skills in a subject.
How much time should I spend on a "First term test 8 mark triple TIPS question"?
The amount of time you should spend on a "First term test 8 mark triple TIPS question" will vary depending on your own skills and knowledge, as well as the complexity of the question. However, as a general guideline, try to allocate around 20-25 minutes to answer this type of question. It is important to manage your time effectively and not spend too much time on one question, as there will likely be other questions to answer in the test.
How can I prepare for a "First term test 8 mark triple TIPS question"?
To prepare for a "First term test 8 mark triple TIPS question," it is important to review and understand the key concepts and topics that may be covered in the test. Practice answering similar types of questions and familiarize yourself with the TIPS framework. It may also be helpful to create study notes or flashcards to aid in your revision. Finally, make sure to manage your time effectively during the test and read each question carefully before answering.
