Fischer Projection to Haworth/Chair Conformation
  • Thread starter Thread starter ngu9997
    Projection
Determining whether a ring will be in the beta or alpha configuration in the Haworth projection or chair conformation cannot be done solely by examining the Fischer projection; prior knowledge is necessary. In aqueous solution, glucose exists in both open and closed forms, which are in equilibrium. The conversion between these forms involves the rotation of the C-1 to C-2 bond, leading to the formation of two anomers, alpha and beta, through a process known as mutarotation. In glucose, the beta anomer is more prevalent than the alpha anomer, although this trend may vary among different monosaccharides.
ngu9997
Can you tell if the ring will be beta or alpha in the haworth projection, chair conformation by just looking at the Fischer projection, or must you be told first before creating the two from the Fischer? If so, could someone explain how? I've seen a bunch of websites and they all seem to say that you won't be able to tell from a Fischer alone.
Chemistry news on Phys.org
In aqueous solution, glucose exists in both the open and closed forms. These two forms always exist in equilibrium. In the process of converting from closed to open form and then back to closed form, the C-1→ C-2 bond rotates. This rotation produces either of the two anomers. We term this phenomenon of opening of the ring, rotation of the C-1→ C-2 bond and the subsequent closing of the ring as mutarotation. So as a result of mutarotation, both the α and β anomers are present in equilibrium in solution. In the case of glucose, β anomer is more predominant than α anomer. This may not be the case with all the monosaccharides.
https://www.khanacademy.org/test-pr...d-ketones/a/cyclic-hemiacetals-and-hemiketals
I came.across a headline and read some of the article, so I was curious. Scientists discover that gold is a 'reactive metal' by accidentally creating a new material in the lab https://www.earth.com/news/discovery-that-gold-is-reactive-metal-by-creating-gold-hydride-in-lab-experiment/ From SLAC - A SLAC team unexpectedly formed gold hydride in an experiment that could pave the way for studying materials under extreme conditions like those found inside certain planets and stars undergoing...
10K
  • · Replies 25 ·
