MHB Fish Pond Challenge: Show Equilibrium Variation with $R_f$
The discussion centers on a differential equation modeling fish population dynamics in a pond, influenced by fishing rates. For removal rates less than a quarter of the equilibrium population, the fish population stabilizes at an equilibrium between half and the full capacity of the pond. Conversely, if the removal rate is equal to or exceeds this threshold, the population may decline significantly, potentially leading to extinction. Participants seek solutions for both scenarios, emphasizing the implications of fishing on ecological balance. The challenge highlights the importance of understanding population dynamics in resource management.
lfdahl
MHB
Suppose a pond contains $x(t)$ fish at time $t$, and $x(t)$ changes according to the DE:
\[\frac{\mathrm{d} x}{\mathrm{d} t} = x\left ( 1-\frac{x}{x_0} \right )-R_f\]
where $x_0$ is the equilibrium amount with no fishing and $R_f > 0$ is the constant rate of removal due to fishing. Assume $x(0) = \frac{x_0}{2}$.
(a). If $R_f < \frac{x_0}{4}$, solve for $x(t)$ and show that it tends to an equilibrium amount between $\frac{x_0}{2}$ and $x_0$.
(b). What happens if $R_f \geq \frac{x_0}{4}$?
Mathematics news on Phys.org
There was a https://mathhelpboards.com/calculus-10/help-derivative-22779.html on logistic growth with constant harvesting a few months ago.
In particular, if we start with the system given in post #5 there, and we non-dimensionalize by introducing a new time $\tau := (r K) t$ and a new unknown $x(\tau) := P(t(\tau))$, then in these new terms we have
\frac{dx}{d\tau} = \frac{1}{rK}\frac{dP}{dt} = P\left(1 - \frac{P}{K}\right) - \frac{H}{rK} = x\left(1 - \frac{x}{K}\right) - \frac{H}{r K}.
This is the system given in the challenge if we set $K := x_0$, $R_f := \frac{H}{r K}$ and we abuse notation by denoting non-dimensional time again with $t$ instead of $\tau$.
It is nice to see a problem on population dynamics, by the way.
Thankyou very much, Krylov! (Handshake)
May I ask for the answers of (a). and (b). in the challenge, based on the logistic growth model, you refer to?
Suggested solution:
\[\frac{\mathrm{d} x}{\mathrm{d} t}=x-\frac{x^2}{x_0} - R_f=-\frac{1}{x_0}\left ( x-\frac{x_0}{2} \right )^2+\left ( \frac{x_0}{4}-R_f \right ).\]
Let $\frac{1}{\sqrt{x_0}}\left ( x-\frac{x_0}{2} \right )=y(t)$, so that $\sqrt{x_0}dy = dx$ and $y(0) = 0$.
Also, let $a^2 = \left | \frac{x_0}{4}-R_f \right |$. In these terms the D.E. is
\[-dt = \frac{\sqrt{x_0}dy}{y^2\mp a^2}\]
where $a^2 = 0$ if $R_f = \frac{x_0}{4}$, negative if $R_f < \frac{x_0}{4}$, and positive if $R_f > \frac{x_0}{4}$.
(a). When $R_f < \frac{x_0}{4}$, $-t = \frac{\sqrt{x_0}}{2a}\ln \left ( \frac{a-y}{a+y} \right )+c$. Since $y(0) = 0$, we have $c = 0$, and so
\[e^{\frac{-2at}{\sqrt{x_0}}}= \frac{a-y}{a+y} = \frac{2a}{a+y}-1\]
i.e. \[y = \frac{2a}{1+e^{\frac{-2at}{\sqrt{x_0}}}}-a.\]
As $t \rightarrow \infty$, clearly $y \rightarrow a$, i.e.
\[\frac{1}{\sqrt{x_0}}\left ( x-\frac{x_0}{2} \right )\rightarrow \sqrt{\frac{x_0}{4}-R_f}\]
and so \[x \rightarrow \frac{x_0}{2}+\sqrt{\frac{x_0^2}{4}-R_fx_0}.\]
(b). When $R_f = \frac{x_0}{4}$, the original equation is
\[\frac{\mathrm{d} x}{\mathrm{d} t}=x-\frac{x^2}{x_0} - R_f=-\frac{1}{x_0}\left ( x-\frac{x_0}{2} \right )^2,\]
which has the obvious constant solution $x(t) = \frac{x_0}{2} = x(0)$.
When $R_f > \frac{x_0}{4}$, \[-t = \frac{\sqrt{x_0}}{a}\arctan \left ( \frac{y}{a} \right ) + c.\]
Again $c = 0$. Now, $-\tan \left ( \frac{at}{\sqrt{x_0}}\right )=\frac{y}{a}$, or $-\sqrt{R_f-\frac{x_0}{4}}\tan \left ( \frac{\sqrt{R_f-\frac{x_0}{4}}}{\sqrt{x_0}}t\right ) = \frac{1}{\sqrt{x_0}}\left ( x-\frac{x_0}{2} \right )$, and so
\[x = \frac{x_0}{2}-\sqrt{R_fx_0-\frac{x_0^2}{4}}\: \tan \left ( \sqrt{\frac{R_f}{x_0}-\frac{1}{4}}\: \cdot t\right ).\]
This is a decreasing function of $t$, which becomes $0$, when $\tan \left ( \sqrt{\frac{R_f}{x_0}-\frac{1}{4}}\: \cdot t\right ) = \frac{x_0}{2\sqrt{R_fx_0-\frac{x_0^2}{4}}}$.
So, the fish population becomes $0$ in a finite time.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
