Fish Reflection: Analyzing Light's Interactions with Water
In summary, JoeyBob found that the image of the fish appears to be 3.13 before the mirror when it is reflected in water.
JoeyBob
256
29
see atached
1/p+1/q=-2/R
So first I looked at where the image of the fish appeared to be when it went through the water surface.
since we can assume the water is flat, R is infinity, so n1/p=-n2/q. plugging in the values (n1=1.29, n2=1, p=3.5) I get q=-0.3686. So the image of the fish appears at 0.369 above the surface or 3.13 before the mirror.
I make this the new q and use the eqn 1/q+1/p=-2/R. calculating for q I get -0.642 or 0.642 behind the mirror.
but the answer is supposed to be 1.64?
The light rays would reflect in the mirror then pass through the water surface, so that is not the natural order in which to solve it. Not sure if it gives the right answer.
JoeyBob said:
so n1/p=-n2/q
The fish and its image would both be below the water surface, so not sure how you get the minus sign.
JoeyBob said:
I get q=-0.3686
You do? The ratio of the distances should be as the ratio of the indexes.
i think this is where I am confused. The light is coming from the fish. but then it needs to come back to the fish for the fish to see itself.
First light comes off fish and hits water. Then light travels through air and hits mirror. Then light goes back through air and hits water. Then goes through water and hits fish for fish to see?
This seems overly complicated. First I would calculate the position of the image after it hit the water/air interphase. Then after it hit the mirror. then after it hit the interphase again?
The sad thing is that i got this question right on the quiz I am looking at, but now I can't remember how I did it...
As for how I get n1/p=-n2/q, its from n1/p+n2/q=(n2-n1)/R
Since R is infinity (since we assume the interphase is flat), n1/p+n2/q=0. One becomes negative if we put them on the other side.
When I read the question, it seems to suggest the fish is between the air-water interface and a spherical metallic mirror below. What you wrote suggests the mirror is above the air-water interface which itself is above the fish.
Likes JoeyBob
The way I read "3.5m above" was above the water since why else would refractive indexes even be given?
If we assume its 3.5 above the fish, then 1/q+1/p=-2/R, where p=3.5m and R=6.2m
This does indeed give -1.644 m or 1.644 m behind the mirror. What a dumb question.
Who knows what the right answer would be if the sphere was above the water. Way more complicated then...
Likes guv
At first I read the question as concerning the image seen by the fish, but in that case neither the depth of water above the fish nor the refractive index are relevant. Of course, it could be a trick question, but I suggest rather that we are to consider the image as seen by an observer above the water.
Edit: my initial reading was correct.
@JoeyBob, is there a further part to the question, where the depth of water becomes important?
Likes JoeyBob
So let's pretend there was a person right above the water looking down and I wanted to find how deep the reflection of the fish appeared to be to the person.
Is that when I would use n1/p+n2/q=(n2-n1)/R where n2 is 1.29 and p=3.5?
Likes JoeyBob
The use of spherical lens equation should be correct where you let R approach infinity. To me this problem is worded poorly. Based on you said, it seems to be asking for the position of the secondary image (from a first virtual image under water) formed in the mirror above water. You probably need to combine the spherical lens equation + mirror equation.
You know what, after thinking about it and reading it a few more times I think I know what it means. The fish 3.5 m above the mirror. The fish is also 3.5 m deep. So the mirror is actually 7m deep. Very poorly worded question.
Since the mirror is underneath, I can find the location of the reflection the fish sees from 1/p+1/q=-2/R.
Then if I wanted to find where a person right above the water saw the reflection, I would use the eqn haruspex linked, n(water)=D(real)/D(apparent) where I am looking for D(apparent) and the D(real) is 7m+(how far behind the mirror the image is)
I believe the question deliberately contains ‘distractors’ – data not required to solve the problem. This is to test/exercise your understanding.
The fish looks directly at the sphere and sees its reflection – a virtual image behind the sphere.
There is no refraction as the rays are always in water. So the refractive index is not needed.
The amount of water above the fish makes no difference.
Only the fish-to-sphere distance and the sphere’s radius are required.
The ray diagram (turned on its side) is just the same as for air, like this:
https://buphy.bu.edu/~duffy/PY106/22b.GIF
so you can simply use your formula “1/p+1/q=-2/R“.
Presumably the fish is a red herring.
I just reread the question and you are right... it does say "to the fish". I missed that before.
FAQ: Fish Reflection: Analyzing Light's Interactions with Water
How does light interact with water?
Light interacts with water in several ways. When light passes through water, it may be absorbed, scattered, reflected, or transmitted. The amount of each interaction depends on the properties of the water and the wavelength of the light.
Why is it important to study light's interactions with water?
Studying light's interactions with water is important because water is a vital component of our planet and understanding how light behaves in water can help us better understand and protect our environment. Additionally, many aquatic organisms, including fish, rely on light for survival and studying these interactions can provide insight into their behavior and ecology.
How does the color of water affect light's interactions?
The color of water is determined by the substances present in it, such as algae, sediment, and dissolved organic matter. These substances can absorb or scatter light, affecting its interactions with water. For example, clear water will allow light to pass through more easily than cloudy water, which will scatter and absorb more light.
What is the role of fish in light's interactions with water?
Fish play a significant role in light's interactions with water. They can both reflect and absorb light, which can affect the overall light transmission in a body of water. Fish also use light for communication, camouflage, and navigation, making their interactions with light crucial for their survival.
How can studying light's interactions with water benefit other fields of science?
Studying light's interactions with water has applications in various fields of science, such as oceanography, ecology, and optics. Understanding how light behaves in water can help us better understand the distribution and movement of marine organisms, the health of aquatic ecosystems, and the development of optical technologies for underwater exploration and communication.
