MHB Fishfood12m's question at Yahoo Answers regarding special integrating factors
To find the integrating factor for the differential equation ydx + (2xy - e^(-2y))dy = 0, first verify that the equation is not exact by comparing the partial derivatives. The integrating factor is derived from the expression (My - Nx) / N, leading to μ(y) = e^(2y) / y. Multiplying the original equation by this integrating factor makes it exact, allowing for straightforward integration. The solution to the ODE is given implicitly by C = xe^(2y) - ln|y|.
MarkFL
MHB
Here is the question:
Integrating Factor Help Please!?
I am preparing for a test and need to be able to find the integrating factor of problems similar to:
ydx + (2xy-e^(-2y))dy=0
All I want is how to find the integrating factor. From what I learned u'=U*(My - Nx) / N
That doesn't seem to work for me. Perhaps you can explain how to find it with step-by-step detail.
Thanks!
Here is a link to the question:
Integrating Factor Help Please!? - Yahoo! Answers
I have posted a link there so the OP can find my response.
Mathematics news on Phys.org
Hello fishfood12m,
We are given to solve:
$\displaystyle y\,dx + (2xy-e^{-2y})\,dy=0$
We should first verify that it is not exact:
$\displaystyle \frac{\delta}{\delta y}(y)=1$
$\displaystyle \frac{\delta}{\delta x}(2xy-e^{-2y})=2y$
Since the two partials are not equal, the equation is not exact.
Next, we look at the expression:
$\displaystyle \frac{\frac{\delta}{\delta y}(y)-\frac{\delta}{\delta x}(2xy-e^{-2y})}{2xy-e^{-2y}}=\frac{1-2y}{2xy-e^{-2y}}$
Since this does not depend on $x$ alone, we next look at:
$\displaystyle \frac{\frac{\delta}{\delta x}(2xy-e^{-2y})-\frac{\delta}{\delta y}(y)}{y}=\frac{2y-1}{y}=2-\frac{1}{y}$
Since this depends only on $y$, we compute the integrating factor as follows:
$\displaystyle \mu(y)=e^{\int2-\frac{1}{y}\,dy}=e^{2y-\ln|y|}=\frac{e^{2y}}{y}$
We now multiply the ODE by $\mu(y)$ observing we are losing the trivial solution $y\equiv0$:
$\displaystyle \frac{e^{2y}}{y}\cdot y\,dx + \frac{e^{2y}}{y}(2xy-e^{-2y})\,dy=0$
$\displaystyle e^{2y}\,dx + \left(2xe^{2y}-\frac{1}{y} \right)\,dy=0$
We can now easily see that the equation is exact. Even though you asked only for the integrating factor, I will go ahead and solve the equation.
Since our equation is exact, we may state:
$\displaystyle \frac{\delta F}{\delta x}=e^{2y}$
Integrating with respect to $x$ we get:
$\displaystyle F(x,y)=\int e^{2y}\,dx+g(y)=xe^{2y}+g(y)$
Now, to determine $g(y)$, we will take the partial derivative with respect to $y$ of both sides of the above equation and substitute $\displaystyle 2xe^{2y}-\frac{1}{y}$ for $\displaystyle \frac{\delta F}{\delta y}$:
$\displaystyle 2xe^{2y}-\frac{1}{y}=2xe^{2y}+g'(y)$
$\displaystyle -\frac{1}{y}=g'(y)$
Hence, integrating, and choosing the constant of integration to be zero, we find:
$\displaystyle g(y)=-\ln|y|$
And so we have:
$\displaystyle F(x,y)=xe^{2y}-\ln|y|$
Thus, the solution to the ODE is given implicitly by:
$\displaystyle C=xe^{2y}-\ln|y|$
Another way (without using integrating factor): we can write the equation in the form $\dfrac{dx}{dy}+2x=\dfrac{e^{-2y}}{y}$ which is linear on the dependent variable $x=x(y)$. Now, and using a well-known theorem, the general solution of the equation $x'+p(y)x=q(y)$ is
$xe^{\int pdy}-\displaystyle\int qe^{\int pdy}\;dy=C$
In our case, $p=2,q=\dfrac{e^{-2y}}{y}$ so,
$xe^{2y}-\displaystyle\int \frac{e^{-2y}}{y}\;e^{2y}\;dy=C$
Equivalenly:
$xe^{2y}-\ln |y|=C$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
