Fitting a curve using a spline, Fourier transform, etc.
In summary, the conversation discusses issues with the output of the interpolating polynomial in a MATLAB code. The code includes functions such as fft, polyfit, and polyval to calculate the polynomial and its error at different points. The discussion also mentions testing the code with simpler functions and obtaining debug data from the polyfit function. There is also a question about the use of different formulas for different values of k in the code.
Jamin2112
986
Just wondering if my output seems wrong. The interpolating polynomial looks like it's way off, though I've looked over my code many times and it seems right (?).
clc
clear all
format long
x1=[1:1/10:4];
y1=zeros(1,length(x1));
y1(find(x1<=3))=floor(x1((find(x1<=3))).^2);
y1(find(x1>3))=9*cos(3*x1(find(x1>3))-9).^3;
xx=[1:1/1000:4];
yy=zeros(1,length(xx));
yy(find(xx<=3))=floor((xx(find(xx<=3))).^2);
yy(find(xx>3))=9*cos(3*xx(find(xx>3))-9).^3;
p=polyfit(x1,y1,length(x1)+1);
y30=polyval(p,xx);
ffty1=fft(y1);
fsum=0;
for k=0:15
fsum=fsum+(ffty1(k+1))*(k+1)*exp(2*pi*i*k*(xx-1)/3);
end
for k=16:30
fsum=fsum+(ffty1(k+1))*(k+1)*exp(2*pi*i*(k-31)*(xx-1)/3);
end
f31=fsum/31;
ynakstruct=spline(xx,yy);
ynakcoeffs=ynakstruct.coefs;
ynak=zeros(1,length(xx));
ynak(1)=yy(1);
for k=2:length(ynak)
ynak(k)=ynakcoeffs(k-1,4)+ynakcoeffs(k-1,3)*(xx(k)-xx(k-1))+ynakcoeffs(k-1,2)*(xx(k)-xx(k-1))^2+ynakcoeffs(k-1,1)*(xx(k)-xx(k-1))^3;
end
yclstruct=spline(xx,[0 yy 0]);
yclcoeffs=yclstruct.coefs;
ycl=zeros(1,length(xx));
ycl(1)=yy(1);
for i=2:length(ycl)
ycl(k)=yclcoeffs(k-1,4)+yclcoeffs(k-1,3)*(xx(k)-xx(k-1))+yclcoeffs(k-1,2)*(xx(k)-xx(k-1))^2+yclcoeffs(k-1,1)*(xx(k)-xx(k-1))^3;
end
figure;
subplot(2,2,1)
hold on
plot(xx,yy,xx,y30,'-')
legend('yy', 'y30')
e1=(1/3001)*norm(y30-yy,1);
title(sprintf('Error: %d', e1))
subplot(2,2,2)
hold on
plot(xx,yy,xx,f31,'-')
legend('yy', 'f31')
e2=(1/3001)*norm(f31-yy,1);
title(sprintf('Error: %d', e2))
subplot(2,2,3)
hold on
plot(xx,yy,xx,ynak,'-')
legend('yy', 'ynak')
e3=(1/3001)*norm(ynak-yy,1);
title(sprintf('Error: %d', e3))
subplot(2,2,4)
hold on
plot(xx,yy,xx,ycl,'-')
legend('yy', 'ycl')
e4=(1/3001)*norm(ycl-yy,1);
title(sprintf('Error: %d', e4))
x2=[1:1/100:4];
y2=zeros(1,length(x2));
y2(find(x2<=3))=floor(x2((find(x2<=3))).^2);
y2(find(x2>3))=9*cos(3*x2(find(x2>3))-9).^3-9;
p=polyfit(x2,y2,length(x2)+1);
y301=polyval(p,xx);
ffty2=fft(y2);
fsum=0;
for k=0:150
fsum=fsum+(ffty2(k+1))*(k+1)*exp(2*pi*i*k*(xx-1)/3);
end
for k=151:300
fsum=fsum+(ffty2(k+1))*(k+1)*exp(2*pi*i*(k-301)*(xx-1)/3);
end
f301=fsum/301;
ynak(1)=yy(1);
end
ycl(1)=yy(1);
for k=2:length(ycl)
end
figure(2)
subplot(2,2,1)
hold on
plot(xx,yy,xx,y301,'-')
legend('yy', 'y301')
e1=(1/3001)*norm(y301-yy,1);
subplot(2,2,2)
hold on
plot(xx,yy,xx,f301,'-')
legend('yy', 'f301')
e2=(1/3001)*norm(f301-yy,1);
subplot(2,2,3)
hold on
subplot(2,2,4)
hold on
legend('yy', 'ycl')
fft(x) returns the Fourier coefficients for the function x given by sample points
polyfit(x,y,n) returns n polynomial coefficients for a polynomial fitted to the points given by the vectors x and y
polyval(p,x) returns the values for a polynomial with coefficients given in the vector p at the points in the vector x
So my spline things seem to be working out. It's just the other two that are looking way off, even though I've checked my code a bunch. Just wondering if maybe you can think of some numerical reason why this might be the case.
Can you get some debug data from the poly fit?
Did you test it with an easier function? Or with more sampling points? The "fit" has as many equations as the polynomial has degrees of freedom, so it is not a real "fit" here.
What happens to ffty1, and where do you plot it?
Isn't it asking for a polynomial of order 30? So I should be getting those coefficients from the smaller set of 31 data points y1, for a polynomial of order 30 with coefficients p={c0, c1, ..., c30}, and I can evaluate it at the larger set of data points using polyval like I did.
% Get the Fourier coefficients (complex #'s) for the 31 pts of data
ffty1=fft(y1);
% Use those to construct the function f31 at the pts xx={1, 1.01, 1.02, ... 4.0}
fsum=0;
for k=0:15
end
for k=16:30
end
f31=fsum/31;
Sure, but you use 31 data points to determine 31 coefficients. That is just a linear equation system, and it should have a unique solution, where the polynomial hits all 31 points.
f31=fsum/31;
fsum is a function? Oh, okay.
I don't understand why you need two different cases here.
Could you explain the second bullet point to me?
for k=0:15
end
for k=16:30
end
Why do you use different formulas for k<=15 and k>15?
Isn't that what it shows on the assignment?
Right, but I don't understand the reason there either. It might be related to the specific way the Fourier transform is calculated.
Related to Fitting a curve using a spline, Fourier transform, etc.
1. What is a spline and how is it used to fit a curve?
A spline is a mathematical curve that is used to fit a set of data points. It is created by connecting multiple polynomial functions together to create a smooth curve that passes through the data points. Spline curves are commonly used in data analysis and visualization to estimate values between data points and to smooth out noisy data sets.
2. How does a Fourier transform help in curve fitting?
A Fourier transform is a mathematical tool that is used to decompose a function into its component frequencies. This allows for the identification of repeating patterns and trends in a data set, which can then be used to fit a curve. By analyzing the frequency components of a function, a Fourier transform can help to identify the best curve to fit the data.
3. What are the advantages of using a spline over other curve fitting methods?
One advantage of using a spline is that it can handle data sets with gaps or missing values. Spline curves are also flexible and can be adjusted to fit different types of data sets, such as linear, quadratic, or cubic data. Additionally, spline curves are smooth and can accurately capture the overall trend of the data without being affected by outliers.
4. Are there any limitations to using Fourier transforms for curve fitting?
One limitation of using Fourier transforms for curve fitting is that it assumes the data is periodic. This means that the data repeats itself at regular intervals, which may not always be the case in real-world data sets. Additionally, Fourier transforms may not be as accurate for fitting data with sharp corners or abrupt changes.
5. How can I determine which curve fitting method is best for my data?
The best way to determine which curve fitting method is most suitable for your data is to understand the characteristics of your data set. If your data has gaps or missing values, a spline may be a good choice. If your data has repeating patterns, a Fourier transform may be more appropriate. It is also helpful to try out different methods and compare the results to see which one best captures the overall trend of your data.
