Fitting a quadric function to a set of points
In summary: Use a 'linear approximation,' where the approximation is just a straight line between the point and the surface. This is more accurate than (a), but it's not as accurate as (c), which is to fit the surface using a polynomial of degree at most n, where n is the number of points in the set. Thanks for the help!In summary, Dave's set of points fit a quadratic surface using ordinary least squares, but he is not sure about a8 and a9 in the function. A9 is supposed to be f, but Dave is not sure what to do with a8 in the equation for M [a b c d e f]^T
daviddoria
97
I have a set of points and I want to find a "best fit quardric surface" through the points. I did the following:
1) Assume the function is in the form:
[tex]a x^2 + b y^2 + c xy + d x + e y + f = z[/tex]
2) Make a nx6 matrix of the points put into (1), that is A=:
x1^2 y1^2 x1y1 x1 y1 1
x2^2 y2^2 x2y2 x2 y2 1
xn^2 yn^2 xnyn xn yn 1
3) Make an nx1 matrix of the z values of the points b =
z1
z2
zn
4) Solve [tex]M [a b c d e f]^T = b[/tex]
Now I have a function that will plot a quadratic surface given the following a0 - a9:
[tex]F(x,y,z) = a0*x^2 + a1*y^2 + a2*z^2 + a3*x*y + a4*y*z + a5*x*z + a6*x + a7*y + a8*z + a9[/tex]
clearly a0 = a, a1 = b, a2 = 0, a3 = c, a4 = 0, a5 = 0, a6 = d, a7 = e
But I'm not sure about a8 and a9. I think a9=f, but what do I do with the coefficient of z (a8) in F(x,y,z) ?
Thanks,
Dave
Steps 1-3 are fine, but the equation in step 4 is overdetermined and can't be solved. If by 'best fit' you mean ordinary least squares, the applicable equation for step 4 is:
[tex]M^TM [a b c d e f]^T = M^Tb[/tex]
The last part with the 2nd equation I don't follow at all.
1) Hm... isn't it just the standard least squares solution, or
[tex]Ax = b[/tex]
[tex]x = A^{-1}b[/tex]
or in this case since A is not invertible
[tex]x = pinv(A) b[/tex]
where pinv is the pseudo inverse?
2) The second part - I was saying that in order to "see" this fit, I have a function in a toolbox that will plot implicit functions (I guess the zero level set?) in the form F(x,y,z). I was asking how the unknowns that I solved for in steps 1-3 would fit into that F(x,y,z) form.
Thanks for the help so far!
Dave
The coefficient a8 should be -1. So you're subtracting z from both sides of your original equation. a9 should be f like you said.
Where did you get [tex]a8 = -1[/tex] ?
It seems to work with some point sets, but for others (points sampled from a sphere, for example) the result is wrong (it says all of the coefficients are 0). Is there a reason that would happen?
Thanks,
David
Thanks,
David
The a8 = -1 is because a8 is the coefficient of z, and your original equation is f(x,y) = z while your plotting function's equation is f(x,y,z) = 0, so we need to subtract z from both sides of the original to get the equations to match up. That gives f(x,y) - z = 0, so the coefficient of z is -1.
It giving all zero coefficients for a sphere is probably a problem with your fitting method, not with the plotting method. You're fitting f(x,y) to the point set, and that's fundamentally a 'height field' where z is only allowed to have one value for a given x,y. A sphere is not a height field; it will have multiple values for some x,y pairs. If your sphere point set is on the plane z=0, then the best fitting 'height field' to that point set actually is the plane z=0, so all the coefficients your solver solves for should come out to be zero. If you want to solve for a general quadric in which all 9 coefficients are free to vary, you need to use a different fitting method.
Zaphos,
You have been very helpful, thanks! You are right on - I just thought it was an "error", but in fact it makes a lot of sense that the plane is the best fit to a set of sphere points.
Do you have a recommendation of a similar non-height field type of fitting procedure?
Thanks,
Dave
Unfortunately that fitting problem is a lot trickier ...
With the height field method, your 'error' was 'distance in z from the point to the surface' which falls out quite naturally from the function f(x,y) = z. But when you have a surface implicitly defined by f(x,y,z) there is no similarly convenient and meaningful error measure. Instead you have two basic options:
(a) Use 'geometric distance,' where your distance is the actual shortest distance from the point to the surface. This is the best approach in terms of accuracy, but unfortunately there isn't afaik a simple expression linear for that shortest geometric distance to a quadric, so you end up with a non-linear problem and typically need some iterative approach to solving it: you guess a set of coefficients, find the points on that surface which are closest to your data points, update your coefficients based on that matching, and repeat until satisfied. You might check "Orthogonal Distance Fitting of Implicit Curves and Surfaces" for a detailed algorithm -- http://www.springerlink.com/content/a8hph1jrfkp9u92h/
(b) Use 'algebraic distance,' where your distance is simply defined by f(x,y,z), since the f() = 0 on the surface and is non-zero away from it. This is much easier -- you could extend your current solution to do it -- but also degenerate, as you can see that you can shrink the error of fit trivially just by scaling down all the coefficients uniformly, even though that doesn't change the actual surface at all. So you need to introduce some additional constraint on how those coefficients are allowed to change, which in turn may introduce singularities ... so some care need be taken with the exact constraints used. In a few special cases, eg for spheres, you can find a constraint that works out just right, and gives you the same result as geometric distance fitting. But I don't think there's quite such a nice constraint for quadrics, so fundamentally it's not going to give the 'best fit' directly.
For more on algebraic surface fitting I like Pratt's paper "Direct Least-Squares Fitting of Algebraic Surfaces" -- http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.18.6178 -- which has the geometric-equivalent solution for spheres and also does suggest a related iterative approach for quadrics.
FAQ: Fitting a quadric function to a set of points
What is a quadric function?
A quadric function is a polynomial function of degree 2, also known as a second-degree polynomial. It has the general form of f(x) = ax^2 + bx + c, where a, b, and c are constants and x is the variable.
Why would someone want to fit a quadric function to a set of points?
Fitting a quadric function to a set of points allows for the creation of a curve that accurately represents the data and can be used for prediction or modeling. It also allows for the identification of trends and patterns in the data.
How do you fit a quadric function to a set of points?
The most common method to fit a quadric function to a set of points is by using the least squares regression technique. This involves finding the coefficients a, b, and c that minimize the sum of the squared differences between the actual data points and the predicted values from the quadric function.
What are the limitations of fitting a quadric function to a set of points?
Fitting a quadric function to a set of points may not accurately represent the data if the underlying relationship between the variables is not quadratic. It also assumes that the data points are evenly distributed and do not contain significant outliers.
Are there any alternative methods for fitting a quadric function to a set of points?
Yes, there are other methods such as using a quadratic spline or interpolating the points using a quadratic polynomial. These methods may be more suitable for data with unevenly distributed points or significant outliers.
