Fixed effective charge in flat band voltage
In summary, the flat band voltage in a MOS capacitor is the voltage at which the fixed charge at the surface and the external voltage cancel each other out, resulting in a net voltage of zero across the capacitor.
anhnha
181
I am having a hard time understanding flat band voltage in MOS capacitor.
Please see the picture below about MOS capacitor.
Q0 is a fixed effective charge at the surface between oxide and semiconductor and it is positive here.
The voltage across the oxide caused by the fixed charge ψox = -Q0/Cox.
So we need to use an external voltage to cancel this voltage ψox.
What I don't get here is the direction of external voltage for cancelling ψox.
As you can see from the picture, it has the same direction as ψox.
Should it be in the opposite direction so ψox can be cancelled?
Thank you.
No, the external voltage should be in the same direction as ψox for it to be cancelled. In other words, the voltage of the MOS capacitor is the sum of the fixed charge voltage (ψox) and the external voltage. When the two voltages are equal and opposite, they cancel each other out and the total voltage across the capacitor is zero, which is known as the flat band voltage.
FAQ: Fixed effective charge in flat band voltage
What is fixed effective charge in flat band voltage?
Fixed effective charge in flat band voltage refers to the net charge present in the semiconductor material at the interface between the semiconductor and the insulating layer. This charge is fixed and does not change with applied voltage.
How is fixed effective charge measured?
Fixed effective charge is typically measured using a technique called capacitance-voltage (CV) profiling. This involves measuring the capacitance of the semiconductor-insulator structure at different bias voltages and using this data to calculate the fixed effective charge present at the interface.
Why is fixed effective charge important in semiconductor devices?
Fixed effective charge plays a crucial role in the operation of semiconductor devices, particularly in metal-oxide-semiconductor (MOS) devices. It affects the threshold voltage, charge storage capacity, and overall performance of these devices.
What factors can affect the value of fixed effective charge?
The value of fixed effective charge can be influenced by various factors, including the type and quality of the insulating layer, the type of semiconductor material, the presence of impurities or defects at the interface, and the processing techniques used to fabricate the device.
Can fixed effective charge be modified or controlled?
Yes, the fixed effective charge can be modified or controlled by engineering the properties of the insulating layer or by introducing additional charge at the interface using techniques such as ion implantation or surface passivation. This allows for the optimization of device performance and can be used to reduce unwanted effects such as charge trapping and leakage currents.
