Fixed Speed Wind Induction Generator
In summary, the conversation discusses the possibility of an older, fixed speed wind induction generator connected directly to the grid through a gearbox and transformer. The question is raised about what would happen if the wind speed was 0 m/s and whether the generator would act as a motor, consuming electricity from the grid instead of supplying it. It is also questioned how older windmills keep the rotor at a constant speed without electronics for control and what happens at higher wind speeds. The understanding is that the blades are designed to spin at certain wind speeds to produce the grid's frequency, with the potential for stalling and not producing electricity at higher speeds. The conversation also notes that connecting an AC wind generator directly to the grid is forbidden.
nand_1
Hi,
I'm sure there is a simple answer to the following question that's got me thinking lately but I'm unsure (it's more of a hypothetical question out of interest and not homework).
If a simple older type fixed speed wind induction generator was connected directly to the grid via a gearbox and a transformer (as per attached diagram) and if the wind speed = 0 m/s, would the generator then act as a motor rotating the blades with an electrical frequency locked to the grid's frequency?
Based on torque-slip characteristic, if the stator leads the rotor with a positive slip (which is the case here), then you have a motor. Would this mean that the windmill now consumes electricity from the grid it's meant to be supplying?
Also, how do older windmills keep the rotor at a constant speed when there are no electronics to for control? What happens at higher wind speeds? Would the electrical frequency then go out of sync with the grid?
My understanding is that the blades are designed to spin at certain wind speeds. Any faster and the turbulence effect kicks in causing the blade to stall and thus no longer produce electricity. Hence, only spinning at a rate that produces the grids frequency.
Note that I'm talking about older wind generators with no power electronics to control the pitch.
Regards,
N
connecting an AC wind gernerator directly to the grid is forbidden. But if you did, yes it might act like a motor.
Old wind generators were probably DC, or did not connect to the grid at all. They just supplied local loads.
FAQ: Fixed Speed Wind Induction Generator
What is a fixed speed wind induction generator?
A fixed speed wind induction generator, also known as a squirrel cage induction generator, is a type of generator used in wind turbines to convert wind energy into electricity. It is called "fixed speed" because its rotational speed is fixed, regardless of the wind speed.
How does a fixed speed wind induction generator work?
As the wind turns the blades of the turbine, the rotor of the generator also turns. This rotation creates a magnetic field which induces an electrical current in the stator windings of the generator. The electricity produced is then transmitted to the power grid for use.
What are the advantages of a fixed speed wind induction generator?
Fixed speed wind induction generators are simple in design and have a lower cost compared to other types of wind turbines. They also do not require a complex control system, making them easier to maintain.
What are the disadvantages of a fixed speed wind induction generator?
One of the main disadvantages of a fixed speed wind induction generator is that its output is limited by the fixed rotational speed. This means that it cannot efficiently capture energy from varying wind speeds. It also does not have the ability to control reactive power, which can affect the stability of the power grid.
How does a fixed speed wind induction generator compare to other types of wind turbines?
Fixed speed wind induction generators are the most basic and oldest type of wind turbine technology. They are less efficient and have lower power output compared to newer technologies such as variable speed turbines. However, their simplicity and lower cost make them a popular choice for smaller-scale wind energy projects.
