MHB Flagpole Angle: 40 Degrees - What's 3/4 of the Way Up?
  • Thread starter Thread starter oldfart1
    Angle Degrees
The discussion centers on calculating the angle subtended by a flagpole at 3/4 of its height, given that the full height subtends an angle of 40 degrees. The relationship between the height of the flagpole and the distance from the observer is established using the tangent function. By substituting the known angle into the equation, the angle at 3/4 height can be expressed as tan(q) = (3/4) * tan(40 degrees). This allows for the calculation of the angle q using a calculator. The conclusion reached is that the angle at 3/4 of the height is approximately 32 degrees.
oldfart1
a flagpole subtends a angle of 40 degrees.
What angle does it subten 3/4 of the way up.
Answer is supposedly 32 degrees ,but how ?
oldfart
Mathematics news on Phys.org
Let $$y$$ be the height of the flagpole. Let $$x$$ be the distance from the base of the flagpole to the observer.
Then $$\tan(40^\circ)=\dfrac yx$$. Letting $$q$$ be the angle in question we have $$\tan(q)=\dfrac34\cdot\dfrac yx$$
Can you continue?
Can you continue?
Sorry but no. thanks
As Greg pointed out you have $$\tan(q) = \dfrac{3}{4} \cdot \dfrac{y}{x}$$ together with $$\tan(40^{\circ}) = \dfrac{y}{x}$$
That means you can put in $$\tan(40^{\circ})$$ (from the second equation) in place of [math]\dfrac{y}{x}[/math] from the first.
This substitution gives you $$\tan(q) = \dfrac{3}{4} \cdot \tan(40^{\circ})$$
The right hand side of that equation is simply a number your calculator can find for you. Does that make it clearer?
Thanks for your help..I get it
Oldfart
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
